Need Airless Tip Size For SW Pro Classic - Painting - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 01:55 PM   #1
need airless tip size for SW Pro Classic
Just purchased a Wagner 9150:
5/8 HP
.29 GPM
GX-07 Gun
Max Tip .17
I will be spraying interior doors and trim with Sherwin Williams Waterborne Arcylic Latex Pro-Classic. What would be the best tip size to achieve the best look? Same tip on door as trim?
ffgreg is offline   Reply With Quote
Old 03-01-2009, 09:16 PM   #2
www.marylandpainter.net
bikerboy's Avatar
Here's a link to the product data sheet which will give you the info you want. It should also be on the can.
http://www.paintdocs.com/webmsds/web...ype=PDS&lang=E
bikerboy is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Anyone know proper size for room a/c-heat? Duane 70 HVAC 7 10-04-2008 11:17 AM
duct work size justmefixin HVAC 2 09-20-2008 07:59 PM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 01:19 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
