-   -   need advise with wood rot before painting (http://www.diychatroom.com/f4/need-advise-wood-rot-before-painting-142020/)
629RWHPstang 04-29-2012 08:18 PM
4 Attachment(s)
Ok my garage has not been painted since god knows when and im suspect of some wood being soft and may be rotting in a few places.. :mad:
now my plan for this week while recovering from ACL surgery and not working is to to a top notch job restoring the exterior of this garage. I already spent $400 bucks on serwin willams duration paints and primers and plan on re caulking and a extensive sanding job before priming
My question is can anyone tell by looking at these pics exactly how bad or good the wood looks? will i be safe without replacing it?
Thank you so much for your time guys:thumbup:
joecaption 04-29-2012 08:42 PM
You have black mold growing in the soffit area, could be from roof leaks or a total lack of ventilation, that needs to be added, mold killed with bleach and water.
Rotted fasia boards that need to be replaced where it's all split and the nails have rusted.
Gymschu 04-29-2012 08:44 PM
I'm sure I'll get lambasted for saying this, but, yes, that wood can be painted. It is deeply neglected but salvageable. It needs a thorough cleaning to remove chalkiness, dirt, and any mildew. Let dry and apply a long dry oil based primer. The reason I say oil based is because water based primers will wick stains out of that neglected wood and leave a less than desirable finish. If you bought $400 worth of paint you should have plenty to complete the garage.
629RWHPstang 04-29-2012 11:31 PM
yeah i have thought it needed better ventilation for the roof.. i can just drill the holes out and install a pop in vent system? any idea what ones are good that i can pick up from home depot or lowe's? and im praying i dont have to start replacing wood with this job
thanks again guys!
user1007 04-29-2012 11:38 PM
Abatron sells great wood restoration products. Long before I took on restoring antique homes I worked on sailboats I raced.
http://www.abatron.com/buildingandre....html?vmcchk=1
joecaption 04-30-2012 01:07 AM
I just noticed something, looking at the picture of the lower edges of the roof looking up I can see gaps between the tab. There should starter shingle there to prevent water from getting into the soffit area.
Install ridge vent on the peak and just some simple 3" push in vents in each bay would be the easyest way.
You going to need a 3" selkf feeding bit and a HD 1/2 dril.
A hole saw will work, just takes far longer.
629RWHPstang 04-30-2012 10:22 PM
spent 6 hours sanding,calking and priming 2 small windows on it today.. this is going to take a while lol
i was thinking of just putting some wood filler in the cracks or paintable calk or even exterior spackle
