Need Advise For Painting Over Drywall Repair - Painting - DIY Chatroom Home Improvement Forum
Old 04-03-2010, 01:27 PM   #1
Need advise for painting over drywall repair
I recently repaired some nail pops in my house and want to paint back over them. In my experience when you do this, you can always see where the repairs were made as the surface is not exactly the same (may be smoother) as the other parts of the wall. Is there a way to paint over this so you can't see the difference? What steps would I take.
I am using Sherwin Williams Cashmere paint. I was thinking of using 2 coats of Killz primer and then 2 coats of the Sherwin Williams paint again.
Any thoughts? Thanks in advance.
dcusk1971 is offline   Reply With Quote
Old 04-03-2010, 02:34 PM   #2
Remodeling Contractor
you must use a primer first. The reason you still see the patches is the sheen is different unless sealed with the primer.
Old 04-03-2010, 03:41 PM   #3
OP you have a good plan..
spot prime with Kiltz then cover all WITH Kiltz might be good enough before you paint. read the lable...2% CHANCE OF BLEED THRU.
I have done this enough to know they are accuarate in this percentile.
Big Bob is offline   Reply With Quote
Old 04-03-2010, 07:14 PM   #4
Rewards Points: 526
Two keys to success: 1) you have to be sure the pops are adequately filled and sanded, and 2) you have to spot prime the fills and paint the entire wall.
Windows is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Drywall Repair Willie5566 Drywall & Plaster 4 03-11-2010 08:42 AM
New Home - Wavy Drywall Seams Repair ?'s bmmitche Drywall & Plaster 2 07-19-2009 05:28 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
