Need Advice On Paint Job - Painting - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 01:08 PM   #1
Need advice on paint job
I need to repaint my son's bedroom. It is currently a medium shade of blue. It had a wallpaper border and several large posters. Too much glue was used on the wallpaper, so I had to spend a lot of time stripping it and clearing the glue off. I also sanded down that area to remove the glue. I think/hope I got all the glue out.
We now want to go to a slightly lighter shade of blue/gray. In the past I have usually just applied two coats of paint without using primer. I am wondering in this case, given the situation I described above, whether I should use primer first.
So of the options below, which one would you recommend as the best compromise between quality and effort?
1. Two coats of the new paint
2. One coat of primer and two coats of the new paint
3. One coat of tinted primer and one coat of new paint
4. Any other option
Thanks!
narend is offline   Reply With Quote
Old 07-20-2013, 01:18 PM   #2
Painting Contractor CT
Rewards Points: 77
Post
I would go with one coat of primer and two coats of the new paint, but be sure to lightly sand primed walls before you apply two coats of paint.
Good Luck!
KD PAINTING is offline   Reply With Quote
Old 07-20-2013, 02:34 PM   #3
Gymschu's Avatar
Rewards Points: 932
It's critical to get ALL of the adhesive off. If you don't, no amount of primer or paint is gonna hide the dull spots that will appear if you prime/paint over any leftover adhesive. That being said, if you are indeed confident that you got it all off, I would follow the advice of KD.
Old 07-20-2013, 03:09 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
primer( Gardz or Cover Stain or other oil based) 2 coats paint
then you don't have to worry if you got ALL the paste off
Old 07-20-2013, 03:46 PM   #5
Rewards Points: 582
we would make sure all adhesive is off..1-coat - primer tinted same color as paint then apply your top coat...ben sr
Old 07-20-2013, 06:39 PM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
This is the correct answer. If you don't get all the old glue off, and I man ALL of it off it neads to be sealed with Guards or an oil based primer or any paint put on top of it will bubble, crack and not stick well. Once you have all the glue off or sealed then 2 coats of finish paint and you are all done.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-20-2013, 09:44 PM   #7
Rewards Points: 4,796
How many ways are you going to spell this? Have you actually ever used it or did you just hear about it somewhere? It's Gardz.
jeffnc is offline   Reply With Quote
Old 07-21-2013, 02:10 AM   #8
chrisn's Avatar
Rewards Points: 496
The Following 2 Users Say Thank You to chrisn For This Useful Post:
BigJim (07-21-2013), oh'mike (07-21-2013)
Old 07-21-2013, 07:31 AM   #9
A Little Of Everything
Rewards Points: 1,364
This.
Gardz is pretty amazing. If you have any question as to whether you removed all the adhesive, this is your answer.
As always, you'll need two coats of paint.
DrHicks is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 05:19 PM
Paint advice for an entire house with new and old surfaces rightit Painting 5 10-01-2012 08:49 PM
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
