Need Advice On Best Paint For Porch - Painting - DIY Chatroom Home Improvement Forum
Old 09-11-2013, 05:50 PM   #1
Question
Need advice on best paint for porch
I am looking for help on which paint will be the best to use on the railings on my porch. I live in Alabama and they are exposed to direct sun and all the other elements. I intend to refinish soon so any help will be appreciated.
hammer6924 is offline   Reply With Quote
Old 09-11-2013, 06:39 PM   #2
Rewards Points: 13,270
A lot more info is needed.
What are the railings made of?
How long have they been up.
What's on there now?
Old 09-11-2013, 07:41 PM   #3
Gymschu's Avatar
Rewards Points: 466
Yeah, as Joe says, we are basically blind. Have they been painted before? Are they pressure treated? Are they cedar? Do they have stain on them now? Those are questions we have to ask to advise you properly.
For most unfinished railings, I prefer Sherwin-Williams Woodscapes solid color stain. Stain holds up well to the elements, doesn't peel, and is much easier to freshen up/touch-up than paint.
Gymschu is online now   Reply With Quote
Old 09-11-2013, 08:13 PM   #4
re best paint
The railings are pressure treated pine, they are painted with latex paint, they have been up 4 years. Except for the paint deterioration the wood is all good. I have heard oil based paint will stand up to the sun and other elements better.
Old 09-12-2013, 01:19 AM   #5
cdaniels's Avatar
No it won't.I would use a quality 100% acrylic.If they were bare I agree with Gym about the solid stain but since they are already painted a high quality acrylic would be my choice.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 09-12-2013, 02:52 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
After proper prep, sanding, cleaning primer( if needed) I agree, oil is just wrong.
Old 09-12-2013, 07:22 AM   #7
Gymschu's Avatar
Rewards Points: 466
Oil has no flexibility so you can imagine what will happen in the heat/cool cycles of weather. It also will yellow and fade much quicker than an acrylic latex.
Old 09-12-2013, 09:05 AM   #8
Jmayspaint's Avatar
Rewards Points: 534
I agree that oil paint is not the way to go at all.
I do however like the oil modified solid stains, and have had some good results using them over properly prepped failed latex.
Oil modified stains supposedly provide the best of both acrylic and oil. Improved hardness, and flexibility.
This condo building had 6yr old failed latex on all the pickets. They were peeling bad and chalking. After extensive pressure washing and sanding, we applied two coats of Flood Solid Stain. Flood has emulsabond in it already, which I felt would help with bonding to the old chalky paint.
I was just by there the other day, and its still doing great after three years on the sunny side.
After seeing so many latex failures, I have switched almost exclusively to oil modified deck stains (solid), and so far I'm happy with the results.
Zar Solid stain is another one I like, it has a flat finish as opposed to the Flood which is more of a satin.
Jmayspaint is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 06:19 PM
Paint advice for an entire house with new and old surfaces rightit Painting 5 10-01-2012 09:49 PM
Painting Old House Smokin Gun Painting 36 07-05-2011 02:24 AM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
