Is It Necessary To Stain A Deck? - Painting - DIY Chatroom Home Improvement Forum
Old 08-06-2013, 12:08 AM   #1
Is it necessary to stain a deck?
Is it necessary to stain a deck or can I just go straight to sealant? I want to protect the support of my deck and wanted to know what was best to keep it rot free.
johnsorious is offline   Reply With Quote
Old 08-06-2013, 06:00 AM   #2
Rewards Points: 13,950
What are you considering A sealant?
What do you mean by the support of my deck? The joist?
Is this a new pressure treated deck?
What type wood is it?
Old 08-06-2013, 06:57 AM   #3
Gymschu's Avatar
Rewards Points: 922
No, you don't have to stain a deck, especially if you like the gray, weathered look. I like a lot of the clear sealers/wood treatments like CWF from the Flood company. They are inexpensive, provide a clear protection, and keeps your wood looking like wood. You have to retreat the wood every 2-3 years.
Old 08-06-2013, 07:02 AM   #4
Rewards Points: 4,796
I also want to know what you mean by "support" of your deck. Your deck is made of pressure treated wood. The vertical surfaces such as posts must be rated for ground contact (since they are buried, obviously). No water sits on vertical surfaces. The other parts of your deck theoretically will rot long before the vertical surfaces that don't trap water, and the part that's underground can't be finished anyway.
Personally I don't like any finish that leaves a film, and has to be scraped if peeling, before reapplying. I like the penetrating oils that can simply be covered over 2 or 3 years down the road with no prep other than cleaning.
jeffnc is offline   Reply With Quote
Old 08-06-2013, 12:23 PM   #5
Too Short? Cut it Again!
You might want to remind us where you are again and update your profile?
No you do not have to stain or even a treat a deck. It depends on whether you can live with what it looks like after a few years and whether you are willing to let the sun, bugs and all return it to nature. Or if you want to go what many who visit this site do when years later they take on a neglected deck that is going to cost them much more than coating it with something every 3-5 years for as long as it does live.
And think about picking splinters out of kids feet or pets paws because you let the surface degrade too fast.
Ironically if you have a new pressure treated deck, you may not be able to stain it for 6-12 months. Then you can make the decision whether to go with as clear and nice a sealer as you can find, up to a semi-transparent stain, or to a semi-solid stain. You will have to put something on it though.
Old 08-06-2013, 01:57 PM   #6
I live in maine. What I mean by structure is the joist which run into my house. I want to protect it but wanted to know if stain was necessary if not then I would go straight to sealant.
Old 08-06-2013, 04:01 PM   #7
If the structure going into your house rests near or on the ground, you would want to treat it for termites just to start. You probably cannot lay timber on the ground as part of your foundation anyhow.
Otherwise, if I understand you, timber protected from your roof down to near the foundation, or on floors in between, should not need to be sealed or stained unless it shows and you want it sealed or stained for esthetics.
Is this a joist or a central beam going into your house, by the way?
Old 08-06-2013, 04:46 PM   #8
Rewards Points: 5,974
Stain will not protect anything all stain will do is color it.
Old 08-06-2013, 07:46 PM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
Stain is used all the time to protect wood.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 08-06-2013, 08:47 PM   #10
I'm not aware of any standard stain that does not contain ingredients to protect the wood. Even if it were just raw colorant (which it isn't), it would still provide at least a little UV protection.
Old 08-07-2013, 06:50 AM   #11
Sorry I was thinking of like furniture stain. Guess I was more tired than I thought
Deck Stain Help bigmike53 Painting 13 05-29-2013 01:49 PM
used house stain instead of deck stain on a deck yura Painting 5 07-10-2012 04:29 PM
Removing stain from deck machouinard Painting 20 09-08-2011 09:12 PM
Spraying a deck stain hdansjr Painting 3 04-21-2009 11:36 PM
