Necessary To Primer/paint Back Of Wood Molding? - Painting - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 06:50 PM   #1
Rewards Points: 26
Question
Necessary to primer/paint back of wood molding?
Hi- is it necessary to primer and/or paint the backside (invisible side) of wood molding to protect/seal it?
I'm installing crown molding in my kitchen.
fiveomar is offline   Reply With Quote
Old 05-06-2013, 07:49 PM   #2
Roofmaster
Rewards Points: 2,210
No, You don't have to do anything to it.
Old 05-06-2013, 07:56 PM   #3
Too Short? Cut it Again!
Agreed. It will look nicer if you caulk any gaps for a nice airtight look. Make sure you use a paintable caulk. You can have a bit of silicone in it but pure silicone is the work of the devil and you will not be able to paint over it.
Old 05-06-2013, 08:01 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Actually - there isn't a "need, but backpriming ( that's what it's called)can help keep the wood stable and less shrinkage.
In some exterior situations it can give years to a paint job, but that is a different story..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
user1007 (05-06-2013)
wood paint for fireplace box pberm1962 Painting 3 05-02-2013 08:22 PM
Can I cut this wood block out and then just nail it back in? amodoko Building & Construction 15 10-14-2012 09:46 PM
Acrylic Solid Stain vs Oil Semi Trans or Semi solid torxx Painting 19 10-03-2012 08:37 AM
Small leak dripping out of the wood molding in the header kc11 Roofing/Siding 0 03-07-2011 08:31 AM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
