Nails To Use For Exterior Clapboard - Painting - DIY Chatroom Home Improvement Forum
Old 07-08-2005, 12:47 PM   #1
nails to use for exterior clapboard
I have a clapboard exterior house from the `20s. I need to reaffix some of the clapboards which are about 3/4" thick. What type of nails and what size should I use to tighten them up?
thank you...
dvarga is offline   Reply With Quote
Old 07-31-2005, 03:10 PM   #2
aka:awesomedell
Rewards Points: 150
Send a message via MSN to housedocs
If you can hide the nails above the reveal of the siding, use a galvanized 6 or 8P nail, if you must face nail, which is sometimes the only way you can get things to hold, then go with a galvanized finished nail. If you've got wood siding from the 20's it's liable to be very seasoned (meaning hard as hell) and predilling maybe in order to avoid bending the nails instead of driving them. Good luck.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Rusting nails on exterior firsthomegal Painting 7 05-28-2007 05:15 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 10:54 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
Deck nails jimgibson Carpentry 12 10-09-2005 02:22 PM
