Nails Found Under Old Paint - Painting - DIY Chatroom Home Improvement Forum
Old 12-24-2011, 02:42 PM   #1
Rewards Points: 150
Nails found under old paint
Old house built in 1910's. Sanding off inside window frames in prep for painting. Found some flat head nails under previous layer of paint---about the size of roofing nail heads. Have no idea if these are structural or someone just tried to hang curtains.
Would you try to dig these out, or try to pound them in deeper and cover, or what? Afraid they will rust and bleed through latex paint later. Just curious if there is a best way to do this.
Just started painting whole house and expect to find more of these later.
NancyNGA is offline   Reply With Quote
Old 12-24-2011, 02:47 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Prime them with Zin 123- it is actually a good metal primer, besides being a great bonding primer.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-24-2011, 03:39 PM   #3
Registered User
Rewards Points: 4,912
Sanding old paint probably means "lead", try a search in white box at top of every page or "Google" it.....
Gary
Old 12-24-2011, 04:44 PM   #4
Rewards Points: 150
Thanks! Yes I'm aware of possibility of lead. So Zin-123 takes care of the bleeding. What about protruding? I guess I'm just being too picky.
Speaking of nails, here's another one (a big one). Now why would someone do that to picture rail molding? To hang a picture, I guess. Ha! I think I'm going to try to hacksaw it off at the base and sink it. It has already split the molding.
Update: I got this last one out using a chunk of 2x4 to pry against. Minimal damage. Yay!!!
Painting Old House Smokin Gun Painting 36 07-05-2011 02:24 AM
latex paint over oil-based = peeling paint! help! ImaDIYnewbie Painting 5 09-20-2010 05:48 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
