Nail And/or Screw Pops- Permanent Fix? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 11:03 PM   #16
Originally Posted by WoodySoCo View Post
Prime with latex I assume to avoid the dreaded flash?
Fresh Start?
Yes, if your finishing with a sheen though, ask about latex enamel underbody. It's a primer/sealer that provides enamel holdout, which means the primer won't absorb any of the sheen. Your first coat of sheen will be higher over underbody than over a standard primer. I don't think Fresh Start has holdout. Just a thought.
Old 04-13-2011, 12:02 AM   #17
Matthewt1970's Avatar
Rewards Points: 1,098
Originally Posted by mazzonetv View Post
If you can, just simply remove the nails and put screws in a few inches away. IMO, it's only a matter of time before the nails pop again. In my house I went around removing a ton of nails - where I couldn't remove I used a punch to punch them in as far as possible and still put a screw in an inch or two away. Few coats of compound, prime, and then have fun with your Aura..
Yes. Screw pops are almost always from screws being driven in too far. Driving them in more won't help.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 04-13-2011, 05:58 PM   #18
Going with Aura eggshell, so I will look into primer with holdout.
Looks like the BM Regal latex Primer is what I need.
Thanks again!
WoodySoCo is offline   Reply With Quote
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Drywall nail pops repair? ProudMarineDad Drywall & Plaster 1 06-23-2009 09:17 AM
How to Fix nail pops? iminvalid General DIY Discussions 9 08-08-2008 09:25 AM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 09:10 PM
nail pops nat Carpentry 3 11-11-2006 01:48 PM
