Old 04-10-2011, 05:42 PM   #1
Nail and/or Screw Pops- Permanent Fix?
Finding a few in the new house, and want to stop them cold so my super duper Aura eggshell paint job won't need to be fixed for a long time.
Should I...
Dig them out, clean off the head, pound in/drive deeper, prime to stop rust, prime hole to solidify gypsum, fill with compound, sand flush ???
What would you pros do?
WoodySoCo is offline   Reply With Quote
Old 04-10-2011, 06:09 PM   #2
bang them in if nails, screw them in if screws. Place a new screw fairly close by and set it just so the paper dimples without tearing. Spackle, prime, and paint.
bob22 is offline   Reply With Quote
Old 04-10-2011, 06:23 PM   #3
Solutions (handyman)
I agree,... just pound the nails in again and screw the screws a little more. These thing happen over time, especially if it was new construction to start with. Sometimes new wood and the setteling of a building can cause walls to shift and any movement can put stress on the fasteners. Just tighten and fill the holes with a good filler and re-paint. Any rusted naila or screws should be removed or you'll experience the rust showing through the paint.
Mark Harvey is offline   Reply With Quote
Old 04-10-2011, 08:02 PM   #4
A lot of times I set popped nails with a punch. It makes a much cleaner repair than a hammer dimple. But, when you skim them, press the compound in with two or three swipes and then lay it off with the blade almost perpendicular to the wall surface or the compound will bulge.
Right behind you woody!
Old 04-10-2011, 08:27 PM   #5
Thanks guys!
Think I'll be proactive and prime the nails/screws pre-mud to prevent rust and the inevitable popping that comes with it.
Are rust proof nails/screws used by tapers?
Old 04-10-2011, 08:32 PM   #6
the nails and screws have some coating on them but minimal protection offered; only against what little short duration exposure to moisture in the mud and the home air.
Old 04-10-2011, 09:13 PM   #7
If you can, just simply remove the nails and put screws in a few inches away. IMO, it's only a matter of time before the nails pop again. In my house I went around removing a ton of nails - where I couldn't remove I used a punch to punch them in as far as possible and still put a screw in an inch or two away. Few coats of compound, prime, and then have fun with your Aura..
mazzonetv is offline   Reply With Quote
Old 04-10-2011, 09:52 PM   #8
Can I put 2 coats of Aura over the mud w/o priming?
Old 04-10-2011, 10:17 PM   #9
Woody, you don't need to prime the sheetrock fasteners. I'd have gotten at least one callback for rust flashing out of the thousands of rusted fasteners I've spackled over if it was problem. Rust will flash through latex paint, but not joint compound, at least not in your lifetime.
Old 04-10-2011, 11:07 PM   #10
Those ben moore guys claim Aura will hold your house together in a hurricane. Surely a little screw head wouldn't give aura any problems.
Duration is offline   Reply With Quote
Old 04-12-2011, 04:36 PM   #11
sdsester's Avatar
No!
sdsester is offline   Reply With Quote
Old 04-12-2011, 09:29 PM   #12
Painting Company, NY
housepaintingny's Avatar
Always prime repairs, no matter what paint your using.
housepaintingny is offline   Reply With Quote
Old 04-12-2011, 09:34 PM   #13
Super Master Painter
Ole34's Avatar
you can put 1 coat of Aura over a skim coated wall without priming so i think 2 coats over a ''patch'' will be fine
Ole34 is offline   Reply With Quote
Old 04-12-2011, 09:45 PM   #14
I've personally tested Sw Duration home and BM Aura. Neither will hold a sheen over a patch without at least 2 coats or one coat over a primer. Sorry guys... just reporting the facts. "Self priming" is relative.
Old 04-12-2011, 10:24 PM   #15
Prime with latex I assume to avoid the dreaded flash?
Fresh Start?
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Drywall nail pops repair? ProudMarineDad Drywall & Plaster 1 06-23-2009 09:17 AM
How to Fix nail pops? iminvalid General Discussion 9 08-08-2008 09:25 AM
Nail Gun Plastic Nail Casing frustrations smark General Discussion 6 07-07-2008 09:10 PM
nail pops nat Carpentry 3 11-11-2006 01:48 PM
