Nail Hole Filler For Finished Trim Work - Painting - DIY Chatroom Home Improvement Forum
Old 09-28-2009, 04:20 PM   #1
Nail hole filler for finished trim work
I have installed new trim in my home and am looking for the BEST filler for all the nail holes. I primed and painted the trim before installing (sprayed it all) If I could, I would perfer NOT to have to re-paint the entire trim...any ideas out there???? Thanks for all your sugestions!
Paint is SW Pro-Classic white waterborne laxtex.
ffgreg is offline   Reply With Quote
Old 09-28-2009, 04:44 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Caulk will shrink and spackle will tend to need 2-3 coats of paint to have a uniform finish. I would use Painters Putty in your situation as it can be mashed into the holes with your fingers. After a good setup time, I would just touch up the paint.
Old 09-29-2009, 11:21 AM   #3
Too Short? Cut it Again!
I tend to use caulking if I have the gun going anyhow to seal the space between the trim and the wall. Drywall compound works too. Just wipe of the excess with a light touch and a damp rag and touchup with paint. The finishing nail holes are so small you will not need much work.
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
oil vs latex for trim work NoExperience Painting 7 08-31-2008 03:42 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
