Was My Paint Shaken Enough? - Painting - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 06:23 PM   #1
Rewards Points: 2,238
was my paint shaken enough?
Bought a gallon of gray at SW today. This is Harmony. I've painted my entire house with SW Super paint, using 5 different colors and never had this happen before.
When I opened the gray and poured some into a pan there were a few black streaks. Black was one of the tints. This gray is no darker than other shades I've used. Just a different color.
I have to go back tomorrow for a new roller so might take the remainder of the paint to be shaken again.
Startingover is online now   Reply With Quote
Old 04-19-2013, 06:55 PM   #2
Probably not shaken enough. I had one one time that wasn't shaken at all, tints just floating. I had another on a multiple gallon order that was labeled but never shot at all. It happens. It could also have been a tinting mistake, like maybe the wrong base if it's bad enough. Once a base is saturated, meaning it's at its max tinting level, it will no longer absorb tint and the excess will simply end up swirling around perpetually. Colors that approach max tint level for the base will usually reflect a little swirl but not enough to make a difference. Take it back and ask them to shake it again, longer this time.
The Following User Says Thank You to jsheridan For This Useful Post:
Startingover (04-19-2013)
Old 04-19-2013, 06:56 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
They usually send you out the door with a wooden stir stick. Use it.
Everytime I pop a can I give it a stir. Every .Time.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 5 Users Say Thank You to Brushjockey For This Useful Post:
daveplot (04-21-2013), jsheridan (04-19-2013), Startingover (04-19-2013), ToolSeeker (04-20-2013), user1007 (04-20-2013)
Old 04-19-2013, 08:10 PM   #4
Rewards Points: 14,306
I bought two of these, one for a 5 gal. and a smaller one for a 1 gal. bucket.
Amazing how it works, it draws all the paint from the bottom to the top of the can super fast for a total remix.
http://www.bing.com/shopping/red-dev...rrer&FORM=HURE
I've never used a paint stick since I bought them. Far faster.
Old 04-19-2013, 09:10 PM   #5
Rewards Points: 388
Hiya SO,
Was the paint shaken up to begin with? If so, what you're describing is probably not due to the paint non being shaken up enough...What you're most likely experiencing is a not-so-uncommon phenomena called "synoreces" (and, yes, I'm sure that was spelled wrong). New formulations of paint necessary to gain VOC compliancy has resulted in a series of unintended consequences in the behavior of paint. One of the consequences of removing specific solvents (even from latex paints) results in a resin that begins to cure with even nominal exposure to air - even the amount of air between the level of paint in a can and the can lid.
Without these specific solvents to retard the resins want to cure, new, slower drying, exempt solvents have been added to the product to serve no other purpose than to "float" to the surface and act as a barrier to the layer of air in the can. This solvent float is clear, but will attract glycol, containing traces of tinting colorants, and appear on the surface most often as a black, gray, silver (etc) "stain"...
This "float" may begin within minutes, to a few hours, after paint has been shaken and is perfectly harmless to the product. It mixes back into the paint easily, or may be poured off before painting. To take the can back to SW to shake won't hurt anything, but it won't stop the process from happening again, though. Good luck and happy painting.
ric knows paint is offline   Reply With Quote
The Following 2 Users Say Thank You to ric knows paint For This Useful Post:
ddawg16 (04-21-2013), Startingover (04-19-2013)
Old 04-19-2013, 09:24 PM   #6
ric, that was interesting and made sense. Harmony is a lower VOC so I do believe it.
joe, that's a good idea on the stirrer.
Old 04-19-2013, 09:38 PM   #7
Great! I say just pull out the stick and stir- ric says why to do that!
And joe says how to over do that!!
All is right with the world!
The Following 4 Users Say Thank You to Brushjockey For This Useful Post:
Blondesense (04-20-2013), chrisn (04-20-2013), Startingover (04-20-2013), user1007 (04-20-2013)
Old 04-20-2013, 03:56 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
Hummmm, cheap drill, $45, paint stirring attachment,$4
Stir stick, FREE
The Following User Says Thank You to chrisn For This Useful Post:
Old 04-20-2013, 05:48 AM   #9
Rewards Points: 512
but it took 1 whole tree to make that 1 paint stick! think of the environment!!!
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
Old 04-20-2013, 06:00 AM   #10
Rewards Points: 101
This, always stir the paint before using.
JMDPainting is offline   Reply With Quote
The Following User Says Thank You to JMDPainting For This Useful Post:
Old 04-20-2013, 06:02 AM   #11
DIY staff
Rewards Points: 7,174
Not exactly on topic----but always 'box' your paint---
Box?---When you get multiple gallons for a room, dump them all into a clean bucket and stir them all together---
This will help you avoid the heartbreaking situation that occurs when the last gallon is noticably off color---and you have to repaint the entire room----
Every experienced painter I know has a story like that-----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Old 04-20-2013, 08:20 AM   #12
I've heard to always stir but admit I didn't this time. Lesson learned.
ol'Mike, as a novice painter I'm not sure if I'll run out of paint or not. But I do try to stop painting at a certain area, like foyer or short wall, and do the entire section with new paint and not just stop and start in the middle of a big wall. Thanks for explaining what 'boxing' was.
I can't believe I'm almost finished with this 1,430 sf house. Except for some trim, 6 doors, porch ceiling and mst bath, which I'll do at a slower pace.
The Following User Says Thank You to Startingover For This Useful Post:
oh'mike (04-20-2013)
Old 04-20-2013, 11:04 AM   #13
Too Short? Cut it Again!
Stir stick, FREE
Yes but the question with both a drill attachment (and you should use 1/2 inch drill with hammer action) or a paint stick is whether to stir in a clockwise or counter-clockwise direction.
If you plan to use the paint and primer in one as a primer, always stir counter-clockwise. Paint should always be stirred, no matter how much it is shaken, in a clockwise direction.
If you are South of the equator reverse this.
The Following User Says Thank You to user1007 For This Useful Post:
Old 04-20-2013, 12:12 PM   #14
sds, does the equator really affect direction of stirring or are you pulling my leg?
Old 04-20-2013, 12:16 PM   #15
orange peel
deleted. posted in wrong spot
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
