My First Attempt At Wall Painting Is Not Going Well. - Painting - DIY Chatroom Home Improvement Forum
Old 01-01-2008, 06:31 PM   #1
my first attempt at wall painting is not going well.
I've watched people paint and read many articles. It looks simple enough, but I'm having such a problem. I'm painting one accent wall. Half the wall came out perfect, the other half is splotchy and I can't seem to butt up to the corner properly. I did okay with the celing and trim lines. I still need to put one one more coat. I am using Ralph Lauren paint. Any suggestions?
catara is offline   Reply With Quote
Old 01-01-2008, 06:42 PM   #2
Insert catchy title here
AppleMac*Fit's Avatar
Any pictures?
It could be the paint... I've tried lots of different paints, and you can't beat Behr paint (available at Home Depot). Even Consumer Reports states they are the best paint. We always get very consistent results with it.
AppleMac*Fit is offline   Reply With Quote
Old 01-01-2008, 06:48 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
The RL paint kinda stinks
Not in a smelly way, but it's not the easiest stuff to work with
Many professionals, I among them, won;t work with it, or charge extra to do so
I think they spent so much money on the name, the product suffers
#2)
If you still have to add another coat, and you only did one so far, you are doing well
There's no such thing as a true one-coat paint
#3)
Splotchy could be from a number of reasons
It could be the paint, as I mentioned, depending on which RL product you are using, it could be par for the course
It could be the paint needs stirring, it could be cheap roller sleeves or poor technique
A common 'bad technique' is to try and squeeze out the paint from the roller sleeve...rather than apply it, and lay it down off the roller sleeve
Use a good premium sleeve, good technique, good quality paint, and another coat
slickshift is offline   Reply With Quote
Old 01-01-2008, 06:57 PM   #4
fierysun's Avatar
By all means I'm not a professional painter but I hope this helps.
Our previous home had knock down textured walls. When I painted those for the first time I used one of those roller kits. I had to put 2-3 coats on the wall to get rid of all the little white spots that kept popping up.
What really helped me the next time I painted was:
  • Switching to the thickest nap roller I could find. I was able to do one coat with the occasional touch up.
  • Using a good paint brush and not a disposable one.
Trying to keep all my fingers and toes
Personal site
fierysun is offline   Reply With Quote
Old 01-01-2008, 07:15 PM   #5
Oldguy
Rehabber's Avatar
I believe you will get much better results with Sherwin Williams, Benjamin Moore, Dunn Edwards or Vista. Can't keep a wet edge with Behr or Valspar without adding Floetrol.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-01-2008, 10:36 PM   #6
Chicagos Green Contractor
GreenContractor's Avatar
i think slickshift said it best, and I wanted to add let the paint do the work, meaning you shouldn't have to press the roller against the wall to get the paint out.
GreenContractor is offline   Reply With Quote
Old 01-02-2008, 05:03 AM   #7
I DO press too hard. I'll try to ease up.
Old 01-02-2008, 06:21 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 470
As a professional painter( and I am sure most would agree),I would pick ANY paint besides Behr,just forget what CR says.
chrisn is online now   Reply With Quote
Old 01-02-2008, 03:59 PM   #9
Behr paint is not the best by any means, but so-so paint will be even if:
applied evenly
substrate is sealed evenly.
is the substrate is unevenly sealed the it will need two coats, if it is applied to thin then it will need two coats
good luck
by the way, consumer reports has many flaws
BOB STROUD is offline   Reply With Quote
Old 01-02-2008, 06:06 PM   #10
okay, the second coats on and 1/4 of the wall looks terrible
I know I put way too much paint on that area and it looks wet. Is there anything I can do to fix this? By the way, i did not use Behr paint, I used Ralph Lauren because the color was unique and when I asked Home depot if they could match it, they said probably not.
Old 01-02-2008, 06:09 PM   #11
For a homeowner, Behr is some of the best (if not the best) paint. You obviously haven't tried American Standard paint from Lowes - that's bad stuff.
Old 01-02-2008, 06:17 PM   #12
Oldguy
Rehabber's Avatar
Let er dry overnight an see wat she looks like in the mornin. Paint takes a while to dry completely
Old 01-02-2008, 06:27 PM   #13
I have a picture
but am unable to upload it because it's way too big. I'm not much better with computer. You know the expression, those that can't...Teach. Well, that would be me!
Old 01-02-2008, 07:19 PM   #14
okay, figured this out
[IMG]file:///C:/Documents%20and%20Settings/HP_Administrator/My%20Documents/My%20Pictures/wall/IMG_0131.JPG[/IMG] not getting any better in this area.
Old 01-02-2008, 07:20 PM   #15
or maybe not...I'll get at it...
Newbie needs some painting advice bji Painting 8 12-26-2008 12:50 PM
