-   -   my first attempt at wall painting is not going well. (http://www.diychatroom.com/f4/my-first-attempt-wall-painting-not-going-well-15022/)
catara 01-01-2008 07:31 PM
I've watched people paint and read many articles. It looks simple enough, but I'm having such a problem. I'm painting one accent wall. Half the wall came out perfect, the other half is splotchy and I can't seem to butt up to the corner properly. I did okay with the celing and trim lines. I still need to put one one more coat. I am using Ralph Lauren paint. Any suggestions?
AppleMac*Fit 01-01-2008 07:42 PM
Any pictures?
It could be the paint... I've tried lots of different paints, and you can't beat Behr paint (available at Home Depot). Even Consumer Reports states they are the best paint. We always get very consistent results with it.
slickshift 01-01-2008 07:48 PM
#1)
The RL paint kinda stinks
Not in a smelly way, but it's not the easiest stuff to work with
Many professionals, I among them, won;t work with it, or charge extra to do so
I think they spent so much money on the name, the product suffers
#2)
If you still have to add another coat, and you only did one so far, you are doing well
There's no such thing as a true one-coat paint
#3)
Splotchy could be from a number of reasons
It could be the paint, as I mentioned, depending on which RL product you are using, it could be par for the course
It could be the paint needs stirring, it could be cheap roller sleeves or poor technique
A common 'bad technique' is to try and squeeze out the paint from the roller sleeve...rather than apply it, and lay it down off the roller sleeve
Use a good premium sleeve, good technique, good quality paint, and another coat
fierysun 01-01-2008 07:57 PM
By all means I'm not a professional painter but I hope this helps.
Our previous home had knock down textured walls. When I painted those for the first time I used one of those roller kits. I had to put 2-3 coats on the wall to get rid of all the little white spots that kept popping up.
What really helped me the next time I painted was:
  • Switching to the thickest nap roller I could find. I was able to do one coat with the occasional touch up.
  • Using a good paint brush and not a disposable one.
Rehabber 01-01-2008 08:15 PM
I believe you will get much better results with Sherwin Williams, Benjamin Moore, Dunn Edwards or Vista. Can't keep a wet edge with Behr or Valspar without adding Floetrol.
GreenContractor 01-01-2008 11:36 PM
i think slickshift said it best, and I wanted to add let the paint do the work, meaning you shouldn't have to press the roller against the wall to get the paint out.
catara 01-02-2008 06:03 AM
I DO press too hard. I'll try to ease up.
chrisn 01-02-2008 07:21 AM
As a professional painter( and I am sure most would agree),I would pick ANY paint besides Behr,just forget what CR says.:no:
BOB STROUD 01-02-2008 04:59 PM
Behr paint is not the best by any means, but so-so paint will be even if:
applied evenly
substrate is sealed evenly.
is the substrate is unevenly sealed the it will need two coats, if it is applied to thin then it will need two coats
good luck
by the way, consumer reports has many flaws
catara 01-02-2008 07:06 PM
okay, the second coats on and 1/4 of the wall looks terrible
I know I put way too much paint on that area and it looks wet. Is there anything I can do to fix this? By the way, i did not use Behr paint, I used Ralph Lauren because the color was unique and when I asked Home depot if they could match it, they said probably not.
AppleMac*Fit 01-02-2008 07:09 PM
For a homeowner, Behr is some of the best (if not the best) paint. You obviously haven't tried American Standard paint from Lowes - that's bad stuff.
Rehabber 01-02-2008 07:17 PM
Let er dry overnight an see wat she looks like in the mornin. Paint takes a while to dry completely
catara 01-02-2008 07:27 PM
I have a picture
but am unable to upload it because it's way too big. I'm not much better with computer. You know the expression, those that can't...Teach. Well, that would be me!
catara 01-02-2008 08:19 PM
okay, figured this out
[IMG]file:///C:/Documents%20and%20Settings/HP_Administrator/My%20Documents/My%20Pictures/wall/IMG_0131.JPG[/IMG] not getting any better in this area.
catara 01-02-2008 08:20 PM
or maybe not...I'll get at it...
