My Experience With Glidden Paint-photos - Painting - DIY Chatroom Home Improvement Forum
Old 06-22-2007, 09:21 PM   #1
My Experience with Glidden paint-photos
I know you pros out there can do wonders with crappy/mediocre paint, but this was my 1st serious paint job.
Big mistake I made- never use masking tape. I had to re-prime some areas.
I baught that sensitive tape from Ace(more sensitive then the painters tape). Worked beautifully. Never will paint without it. Yes I know u pros dont use tape, but dont forget I suck at this
I used an edger. I did a good job with. Areas, such as 3rd photo down, was the result of masking tape peel.
Red, 2 coats, has too many roller/brush marks. Now I know why to use the good stuff. Blue came out good on 1st coat. All and all im not too upset
I have the Glidden for the master bedrooms next(lighter colors), but for the living room I will definaltey go to my local Sherwin Williams and get the better stuff. Want less brushmarks and want it to spread better.
Question- do any of you use those tiny brushes, like ones to paint model cars, ect, to cover that up? Im not sure how i'll touch that up(3rd photo) w/out a headache.
usaalways is offline   Reply With Quote
Old 06-22-2007, 09:47 PM   #2
made in U.S.A.
Hamilton's Avatar
Originally Posted by usaalways View Post
Yes I know u pros dont use tape...
Not true, I certainly don't have a gifted "cut in" hand.
If I'm doing a dark ceiling against some cream colored crown, for instance, I always tape. My partner doesn't like to tape, too bad for him - I get done faster, but more important the edges look like they were cut with a laser.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 06-22-2007, 10:16 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
I would hit that with my 1" Purdy
Model paint brushes don't have the correct bristles to blend in well, and usually aren't quite wide enough for touch up, but I suppose they might do in a pinch
slickshift is offline   Reply With Quote
Old 06-22-2007, 10:25 PM   #4
1" Purdy
What's a purdy? I tried google searching but came up with "purdy" photos whereas people used that term instead of "pretty"...photos of babies and women which I dont think they meant as paint tools
Old 06-22-2007, 11:05 PM   #5
Workaholic's Avatar
Rewards Points: 268
A purdy is a brand of paintbrush, you can get them at paintstores hardware stores. A good brush makes a good finish, if you have many paint projects comming up you will want a few quality tools. So purdys are the perfect choice. Keep it up and you will get better each time.
I would recomend 1" - 2" angle brush, often called a sash tool.
www.purdycorp.com
Workaholic is offline   Reply With Quote
Old 06-22-2007, 11:09 PM   #6
Guest
Guest
Posts: n/a
I wouldn't use model brushes. Artist's brushes are a different story. They can work quite well in some situations.
Old 06-22-2007, 11:11 PM   #7
I never put much thought into quality of tools.
I decided to go with SW as a dealer is closer then other quality paint stores.
Hmmmm...now tools.
I'll have to look into these. Thanx for the heads up.
Old 06-22-2007, 11:14 PM   #8
Workaholic's Avatar
Rewards Points: 268
The Xl series is a good one, also the pro extra series is also a good line.
Old 06-22-2007, 11:29 PM   #9
how long do these brushes usually last?
Old 06-23-2007, 06:50 AM   #10
slickshift's Avatar
For DIYer? If properly cleaned and stored, years and years
Old 06-23-2007, 12:41 PM   #11
Workaholic's Avatar
Rewards Points: 268
Yep i agree, a diy,er would have them for a very long time.
SW Duration paint - OK to thin with water? plin321 Painting 10 08-11-2007 09:29 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
my painter did not fallow the contract jaskoo Painting 17 11-19-2006 01:21 PM
exterior paint question sherlock Painting 5 07-05-2006 07:31 AM
