More Painting Questions From A Newbie. - Painting - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 11:36 AM   #1
More painting questions from a newbie.
I posted a while back with questions on removing old wallpaper and thanks to your suggestions, I'm almost finished!
My intentions were to only repaint the walls, as the baseboards looked to be in good shape. However, after moving some furniture I discovered one side was poorly painted and it looks like the paint is bubbled up.
Also, after pulling down the drapes, I discovered chipped paint around the windows.
Can I get away with sanding this down and repainting it?
Also, since I'm going to have to repaint baseboards and window seals, in order to match I'll need to repaint my doors, but this paint seems to be a glossy paint. How do I need to go about repainting over it?
Thank you again for all your help. You're all lifesavers. Cherry ones, as a matter of fact.
Tab1975 is offline   Reply With Quote
Old 04-22-2009, 05:02 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Is the chipped paint on the drywall or on the window frame? If it's on the drywall, that may indicate a moisture problem as drywall typically won't peel. The baseboard were probably painted with latex before so you can just paint right over them with latex but if they are still real glossy you might want to give them a light scuffing with some sandpaper.
Old 04-23-2009, 09:26 AM   #3
Hi Matthew! It's actually on the window frame, not the drywall.
Old 04-23-2009, 10:32 AM   #4
Sure, you can sand that then. Any bare wood should get primer.
Old 04-23-2009, 06:59 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
Yuppers!
slickshift is offline   Reply With Quote
Old 04-25-2009, 12:13 AM   #6
Rewards Points: 506
Scrape all loose or failing paint, and sand to smooth out.
To paint over glossy paint, first determine if it is oil or latex. (If high-test rubbing alcohol removes some paint, it's latex.) Scuff sand, clean, and if oil, prime with a bonding primer. Topcoat with two coats of quality trim coating. (I prefer waterbourne enamel; either SW ProClassic or BM Impervo.)
SirWired
sirwired is offline   Reply With Quote
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Tub Surround, Painting, Durock or Greenboard, and Spacking Questions? golfer2b Plumbing 7 04-17-2008 09:59 PM
Painting Exterior Spruce Rough-sawn trim questions Stonemeel Painting 8 09-11-2007 08:00 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
