Old 05-16-2007, 09:53 AM   #1
Moldy Fireplace
I don't know what's going on with my fireplace, it molds along where the wall meets the brick. I thought that something was leaking somewhere, but roof if not leaking. Also I had a mirror hanging above the mantle and the fireplace "wall" molded, dark black mold, as well as the mirror, any suggestions??? Please!!!
ssla is offline   Reply With Quote
Old 05-16-2007, 09:57 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Moldy Fireplace
On what floor level is this fireplace? Basement or 1st floor?
It really sounds like the brick and the home structure have settled over time and have slightly separated from each other, and outside moisture may be coming thru that area that you describe as:
.....it molds along where the wall meets the brick....
Check into that area.
- Build Well -
Old 05-16-2007, 10:20 AM   #3
Moldy Fireplace
It's on the 1st floor, it's a ranch style house
Old 05-16-2007, 10:22 AM   #4
Moldy Fireplace
Oh it was built in the '60's
Old 05-16-2007, 10:43 AM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Moldy Fireplace
Are you sure its mold and not just soot or dust?
Mold needs moisture. Moisture can come from leaks or from condensation. If you have no leaks, and its not soot or dust, then you have condensation. Condensation is cause when you get warm and cold coming together.
First clean the mold off with bleach solution. Done. Then just dry dehumidification and see if it comes back or not. Air conditioning is also dehumidification FYI.
Oh, and you can get a moisture meter to check for moisture. Cheap ones are not too accurate but probably sufficient for your purpose.
Here is a good enough one for $20
http://www.harborfreight.com/cpi/cta...temnumber=2757
Brik is offline   Reply With Quote
Old 05-16-2007, 10:56 AM   #6
Moldy Fireplace
I have bleached it off several times, with it only returning . We have never used the fireplace so I know it's not soot or dust. Do we need to remove our fireplace?
Old 05-17-2007, 01:38 PM   #7
Pro Painter
Moldy Fireplace
Probably don't need to remove the fireplace. But removing the drywall and having a look back there might be a good idea. Could be something behind the drywall attracting and holding moisture.
Paint won't solve this problem.
joewho is offline   Reply With Quote
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
huge fireplace issues krynstar Painting 10 03-10-2007 07:41 PM
Fireplace leaking mmcginn2 Roofing 4 04-23-2006 11:12 AM
Water leaking over fireplace mmcginn2 General Discussion 1 04-21-2006 12:42 AM
