Mold Problem On Bathroom Ceiling Exhaust Fan Not An Option - Painting - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 11:01 AM   #1
Question
Mold problem on bathroom ceiling exhaust fan not an option
I have a mold problem with our bathroom ceiling. We cannot install an exhaust. What is the best way to deal with this problem. The ceiling and walls are plaster.
Bobschnabel is offline   Reply With Quote
Old 08-26-2012, 11:07 AM   #2
Rewards Points: 13,228
Not sure what having plaster has to do with not being able to add a fan. It can be and is done all the time.
Is there at least a window in the room?
Old 08-26-2012, 11:58 AM   #3
Gymschu's Avatar
Rewards Points: 454
An exhaust is necessary to move the air and keep moisture from gathering on the ceiling. If you can't install an exhaust you could at least run a fan in there for an hour or two a day to keep the moisture from just laying on the ceiling and walls.
Old 08-26-2012, 12:36 PM   #4
Too Short? Cut it Again!
Why do you assume you cannot install an exhaust fan?
Old 08-26-2012, 02:17 PM   #5
Bill Kearney
Rewards Points: 1,174
You're dumping a lot of humidity into the room. If you leave it in the room you'll get mold. So you've got to get the moisture out of the air in the room. How you do this is up to you but the most common and sensible way to do this is with an exhaust fan. There are lots of different ways to vent a fan, some more creative than others. But otherwise you're never going to be rid of the mold issue.
wkearney99 is offline   Reply With Quote
Old 08-27-2012, 12:29 PM   #6
Rewards Points: 394
I agree completely. Humidity has to go somewhere; if it is not evacuated with ventilation, it will stay and cause problems. Mold thrives in humidity and moisture.
Will22 is offline   Reply With Quote
Old 08-29-2012, 03:42 PM   #7
Bombastic Idiot
notmrjohn's Avatar
you need a fan. i think everybody has exhausted the topic.
notmrjohn is offline   Reply With Quote
Old 08-29-2012, 05:21 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
Old 08-29-2012, 05:50 PM   #9
Rubbin walls since'79
Brushjockey's Avatar
Im kinda likin this NMJ guy...
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-29-2012, 08:12 PM   #10
Bombastic Idiot
notmrjohn's Avatar
you'll get over it.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
Old 08-29-2012, 08:45 PM   #11
..-probably..
Old 08-30-2012, 04:51 AM   #12
chrisn's Avatar
Rewards Points: 224
you'll get over it.
no doubt
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
How to fix a peeling bathroom ceiling lmaxson Painting 16 02-20-2012 02:55 PM
bathroom ceiling mildew/mold problems ditchdoc7893 General DIY Discussions 3 03-19-2011 07:24 AM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 08:38 AM
Best way to texture a bathroom ceiling DIY-Renovator Painting 3 07-30-2008 10:49 AM
