Mold/Mildew On Drywall Surface - Painting - DIY Chatroom Home Improvement Forum
Old 06-19-2013, 03:15 AM   #1
Mold/Mildew on drywall surface
I just removed some solid vinyl WC from wall and we found mold/mildew stains on surface. We removed drywall and found mold inside. After killing/cleaning mold in wall is there a good product to maybe paint inside wall to inhibit this from happening again? Thanks.
roeldred is offline   Reply With Quote
Old 06-19-2013, 04:10 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
The vinyl paper was holding in moisture causing mold growth. If you no longer have the paper, you should no longer have a problem
chrisn is online now   Reply With Quote
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (06-19-2013), roeldred (06-20-2013)
Old 06-19-2013, 03:19 PM   #3
Too Short? Cut it Again!
I agree with Chris. Just make sure you do not have a slow plumbing leak or pipe or duct condensation issue you need to address before sealing the wall back up again.
The Following User Says Thank You to user1007 For This Useful Post:
Old 06-20-2013, 03:41 AM   #4
Problem is that a solid vinyl WC is going back up. Can we do anything as far as primers to stop it from happening again? Thanks.
Old 06-20-2013, 03:43 AM   #5
Forgot to mention, no plumbing in that area but it is an outside wall underneath a window.
Old 06-20-2013, 04:14 AM   #6
chrisn's Avatar
Rewards Points: 232
As far as I know, there is no primer that will prevent mildew. You are going to have to solve the moisture problem somehow.
Old 06-20-2013, 08:01 AM   #7
Check the flashing for that window!
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 02:23 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
