-   -   Mold/Mildew on drywall surface (http://www.diychatroom.com/f4/mold-mildew-drywall-surface-182096/)
roeldred 06-19-2013 02:15 AM
I just removed some solid vinyl WC from wall and we found mold/mildew stains on surface. We removed drywall and found mold inside. After killing/cleaning mold in wall is there a good product to maybe paint inside wall to inhibit this from happening again? Thanks.
chrisn 06-19-2013 03:10 AM
The vinyl paper was holding in moisture causing mold growth. If you no longer have the paper, you should no longer have a problem
user1007 06-19-2013 02:19 PM
I agree with Chris. Just make sure you do not have a slow plumbing leak or pipe or duct condensation issue you need to address before sealing the wall back up again.
roeldred 06-20-2013 02:41 AM
Problem is that a solid vinyl WC is going back up. Can we do anything as far as primers to stop it from happening again? Thanks.
roeldred 06-20-2013 02:43 AM
Forgot to mention, no plumbing in that area but it is an outside wall underneath a window.
chrisn 06-20-2013 03:14 AM
As far as I know, there is no primer that will prevent mildew. You are going to have to solve the moisture problem somehow.
user1007 06-20-2013 07:01 AM
Check the flashing for that window!
