Mold In Garage - Painting - DIY Chatroom Home Improvement Forum
Old 05-15-2007, 07:23 AM   #1
mold in garage
Relatively new homeowner here (bought my house five years ago). I eventually painted the interior garage walls with white concrete paint in 2004. Last night I started to notice mold growing in a few areas on the wall just above the floor. It also spread to some storage shelves (plastic and wood). Had to throw some stuff away last night because of it. Even my power mitre saw has mold on the metal surface that I can't clean off.
I plan on scrubbing the walls with a bleach solution today. After cleaning is there anything I can apply to the walls to prevent mold?
Maybe it would have been better had I not painted the bare walls! The painted surface allows moisture to condensate and that's probably the cause of my problem.
I know it sounds silly, but I may have to put a dehumidifier in the garage as well.
coeng is offline   Reply With Quote
Old 05-15-2007, 09:09 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
Doesn't sound silly to me
But then, I've got to regularly Boe-Shield* my metal tools or they become rust lumps rather quickly
I live in The Land Of Rust And Mildew
*like a super WD-40 that leaves a waxy film
After mold removal, I'd paint again but with Zinsser's Perma-White
It is the most Mold Mildew resistant paint I've found
slickshift is offline   Reply With Quote
Old 05-15-2007, 09:39 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
There are plenty of painted walls in garages that don't produce mold. I would also suggest that you take a closer look at your exterior roof and gutter drainage system, siding, roof itself, and other areas to determine if there is something else going on.....(example, there could be a leak that is running down the interior of the wall and saturating the lower areas of the garage walls and causing the mold).
I am not stating this as fact, or a definite reason as I obviously have no way of doing an onsite inspection of the areas inside and out.
It's just common practice when correcting any mold or moisture isses to determine 'why' a situation is happening and then eliminate the cause of it.....then do your repairs....
- Build Well -
Old 05-15-2007, 12:17 PM   #4
It just so happens that I had a clogged underground drain in that corner of the garage that I recently cleaned out. It was packed with mud and other debris. This was the cause of water that was seeping into garage wall even when we got only an inch of rain. Since I've cleaned the drain out, I have only seen water in the garage once and that was when we had 6+" of rain with the Apr 07 Noreaster. When you have a crack in your foundation and 6" of rain draining downhill, its gonna seep in eventually. Fortunately not that much seeped in. Well, not that much to warrant a repair easily over $1000. Since half my garage is above ground it easily dries out when I open the door.
Old 05-01-2013, 03:09 PM   #5
Garage Mold
My wife and I moved into a brand new house 6 months ago. Attached garage was insulated, vap-bar, and painted. Noticed 2 days ago that we also have an 8" uniform strip of mold on all three walls at the base(even the wall beside the house).
Because it's uniform, does not stand to reason that it has anything to do with moisture leaking from above but more likely just moisture left from the vehicles.
Is there any leg to stand on to get the builder to do anything here that should have been done in the first place or will we just have to live with it?
Bopper is offline   Reply With Quote
Old 05-01-2013, 04:27 PM   #6
Rewards Points: 5,978
Should have started a new thread only because it can get confusing try to answer 2. But by all means get ahold of the builder and have him look at it.
Old 05-01-2013, 04:51 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
original thread is 6 years old
start a new one ,please
chrisn is online now   Reply With Quote
New Heated Garage: need help! HardcoreCBR General DIY Discussions 12 05-23-2008 07:34 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 10:38 PM
detached garage Kapt Electrical 12 01-17-2007 08:37 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
