Moisture Resistant Primer - Painting - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 10:37 PM   #1
Rewards Points: 2,072
moisture resistant primer
just googled this and read that in BATHROOMS you should use a moisture resistant primer (which SW carries) followed by mildew resistant paint.
Do you pros use moisture resistant primer and is Zinnser Gardz moisture resistant?
Also read that "SICO" is recommended for bad spacklers. Personally I've never heard of it before.
Startingover is offline   Reply With Quote
Old 03-11-2013, 10:50 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Start. Read this. read it carefully.
http://www.rustoleumibg.com/images/t...ACE_SEALER.pdf
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
PinkHarley (03-17-2013), Startingover (03-14-2013)
Old 03-11-2013, 11:18 PM   #3
brushjockey,
I planned to order Gardz, but then wasn't quite sure after googling.
Old 03-13-2013, 08:17 AM   #4
almost ordered Gardz from a Grainger site, then checked your link and yours is 'problem sealer' and the Gardz I found is 'high preformance'.
Didn't realize Zinsser had different Gardzs ?
Old 03-13-2013, 08:24 AM   #5
different label- same thing
The Following User Says Thank You to Brushjockey For This Useful Post:
Startingover (03-13-2013)
Old 03-13-2013, 12:39 PM   #6
Mr. Paint's Avatar
Moisture-resistant primers or "Low-Perm" primers are designed for new drywall to keep moisture from the face paper. It is used alot in sealed buildings with an HVAC controlled environment that is not affected by the outside weather. If the room already has paint on it, then you will need a primer for repairs or intercoat adhesion.
The Painter's Paint Store where QUALITY is ECONOMY
Mr. Paint is offline   Reply With Quote
The Following User Says Thank You to Mr. Paint For This Useful Post:
Old 03-13-2013, 01:15 PM   #7
I am very annoyed at the moment.
Bought the Zinsser Ceiling paint, no problem. Walmart carries it.
CANNOT find Zinsser Gardz. Went to the Pro desk at HD and they didn't know what I was talking about and then they found it, but only in a 5 gal size. I only want one gallon.
I couldn't really find a site online (but will look farther) where I could just order it.
Why is this so hard?
Old 03-13-2013, 04:05 PM   #8
Mr. Paint's Avatar
A store where the pros go, like Sherwin-Williams, Benjamin-Moore, PPG will have it in ones. Also, any wallcovering store will. Try to avoid the big boxes when you need a specialty product or advice. You usually come out empty-handed and mis-informed.
Old 03-13-2013, 04:09 PM   #9
I think it has been said, repeatedly, that availability of Gardz changes from one region to the next. Why? I'm sure I don't know..
Old 03-13-2013, 04:45 PM   #10
TA DA!!!
Learned I can order Zinsser Gardz from Amazon!!!
Old 03-13-2013, 05:32 PM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Originally Posted by Mr. Paint;1136442[COLOR=red
]A store where the pros go, like Sherwin-Williams, Benjamin-Moore, PPG will have it in ones. [/COLOR]Also, any wallcovering store will. Try to avoid the big boxes when you need a specialty product or advice. You usually come out empty-handed and mis-informed.
As brush pointed out, not necessarily, I cannot get it anywhere around me.
The Following User Says Thank You to chrisn For This Useful Post:
Old 03-13-2013, 06:56 PM   #12
BIN is also moisture resistant, though I don't know to the degree of Gardz
The Following User Says Thank You to jsheridan For This Useful Post:
Old 03-13-2013, 07:09 PM   #13
Rewards Points: 5,974
Don't know about BM but SW at least around me does't carry any Zinnzer products.
Old 03-13-2013, 08:43 PM   #14
cdaniels's Avatar
None of my local paint stores carry Zinsser, the only place I can find them locally are the box stores.I understand why the paint stores don't carry it,they want to push their own products but I don't understand why ALL the box stores don't stock the same products.Local environmental regulations? IDK.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 03-13-2013, 09:20 PM   #15
I have read and been told it is considered haz. mat. but if you read the safety sheet on it it really doesn't show anything.
The Following User Says Thank You to ToolSeeker For This Useful Post:
first coat of primer is on the drywall, but it's not pretty wengang1 Painting 14 12-25-2013 07:16 PM
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 08:47 AM
Please help! I'm repainting bedroom furniture and primer is "gunking"! Fun2Learn Painting 12 02-13-2012 07:54 AM
High moisture in slab, should I put down a barrier for travertine? help! eezeekial Tiling, ceramics, marble 15 11-21-2011 06:14 PM
Latex primer over oil base finish.. whalogreg Painting 6 01-28-2011 03:32 PM
