Moisture In The Air - Painting - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 10:07 AM   #1
Moisture in the air
How dry does it need to be to paint outside? We had som rain and the ground is wet but it hasn't rained in a day. Can I go ahead?
PhiL1227 is offline   Reply With Quote
Old 12-12-2011, 10:59 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
If the humidity is too high, it will take longer to dry. As long as the house is dry, and the ambient temperature is desirable (read the can. Probably about 55-80 degrees), you'll be alright.
titanoman is offline   Reply With Quote
Old 12-12-2011, 11:02 AM   #3
I got paint that works in cooler weather. Can I paint parts outside that are covered if it starts sprinkling? The paint works down to 35 degrees
Old 12-12-2011, 11:15 AM   #4
As long as the surfaces you are painting are dry. However, there are some caveats to painting in cooler, damp weather. This has been discussed here, look under these threads:
Low Temperature Exterior Painting Questions
Disaster
Joe
Old 12-12-2011, 01:14 PM   #5
What should the humidity be and the dew point? I got the temperature covered or is all that on the paint. Don't have it here...
Old 12-12-2011, 01:15 PM   #6
I guess humidity is the main factor right now. Thanks everyone so far. I love this place
Old 12-12-2011, 01:18 PM   #7
What is too high for humidity?
Old 12-12-2011, 01:22 PM   #8
Disabled wood vet
titanoman's Avatar
The bucket of paint probably specifies this. I would guess below 70% or so. But people paint when it's 100% so..
Old 12-12-2011, 01:24 PM   #9
Thanks again
Old 12-21-2011, 03:37 PM   #10
Rewards Points: 394
The temperature needs to be 5 degrees above the dew point. This needs to be the standard throughout the drying time for the paint product. Otherwise, you deal with condensation, surfactant leaching, blistering, bubbling, and other adverse conditions.
Will22 is offline   Reply With Quote
Old 12-21-2011, 05:42 PM   #11
NACE Coating Inspector
mustangmike3789's Avatar
Originally Posted by phil1227 View Post
what is too high for humidity?
most acrylic paints are good up to 85% relative humidity and the surface temp should be at least 5 degrees above the dew point and rising. If this info isnt listed on you paint can, you could find the product data sheet on line or get it from the paint store.
mustangmike3789 is offline   Reply With Quote
High moisture in slab, should I put down a barrier for travertine? help! eezeekial Tiling, ceramics, marble 15 11-21-2011 05:14 PM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 01:27 PM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 06:33 AM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 09:29 AM
