Old 05-24-2006, 10:28 PM   #1
Modifying stain color?
I'd be grateful for some quick advice. We discovered very sound cedar siding under aluminum siding and have applied two coats of Cabots Linen. It looks soft and pale yellow under the overhand of the front of the house, but on the front of a gable, over a stone wall, it looks like an egg yolk. Obviously, the color is affected by the light and its position on the house and I should tone it down--but how? Do I just add white stain to the linen color, or can the paint store do something about this? Any advice?
opus111 is offline   Reply With Quote
Old 05-25-2006, 03:48 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
How long ago was the Cabots applied?
How was the cedar prepped before application?
Off-hand, w/o these answers, I'd say it should even out some over time, but it's probably the wood itself that has made the stain look different
Usually it's not really a good DIY project to try and "even it out" with more stain as often it makes it worse
Some more information might help determine if something can be done
slickshift is offline   Reply With Quote
Old 05-25-2006, 03:51 PM   #3
The Cabots was just put on this week--and over previously stained siding. Same two coats on each. I think the problem is one of lighting--one gets lots of sun, the other is in the shade of the overhang. Any thoughts?
Old 05-25-2006, 04:02 PM   #4
slickshift's Avatar
Could be lighting
But the thing is, if the light affected the coatings on there (it's highly unlikely they were treated before sided), it's a little too late to try and fix that now
What I mean is, the stuff under the stain you just put on is the problem-whether it's the sun or what-and now it's too late to brighten the wood and even that out
I would not suggest another coat of tinted stain to try and even it out
At least in general, and w/o seeing it
Their is great potential to make it worse
The exception would be, take some good pics to a Paint Shop (not a paint dept.) and see if they have a suggestion
If it's not too bad of a change, they may have something that might work
But they'll really need to see it to make a call on that
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 11:50 AM
Newbie needs some painting advice bji Painting 8 12-26-2008 01:50 PM
Painting walls different color at an outside corner J187 Painting 8 08-16-2006 08:16 PM
