hello,
Has anybody ever tried to mix, say, a gallon of satin with a gallon of semi-gloss? I have some of each in a polyurethane made by Zinsser (Bullseye). They're interior and water based. Thanks.
Jamie
I'm a little confused. Z's bullseye is a primer.
Are you talking about clear finishes?
Be more specific with what you have- but if they are from the same co , and you mix really well and mix frequently so that the flattening agents in the lower sheen stay mixed- you are probably fine.
Within the same manufacturer there should be no chemical reaction. There are certain things you should keep in mind:
Mix in a clean container that will hold at least 3 gallons
You will end up with a unique sheen; make sure you have enough for three coats. You may want to use a first coat of Zinsser's Seal Coat, an excellent interior sanding sealer.
Do not power-mix. You may bubble the product.
Thoroughly incorporate all the flatting agent to prevent uneven gloss.
Re-stir between coats.
BTW, 3M makes a mint green colored sandpaper that is made specifically for latex finishes. This will work great with your project.
Thanks so much for the quick and helpful replies. Yep, it's a clear product from Zinsser called "Ultimate Polyurethane". I'll tackle it tomorrow!
Jamie
Mixing brands of a similar product will usually work. However, if anything were to go wrong, both manufacturers will diown the project. Why don't you call Zinsser's help line and ask them?
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
