Mixing Paint - Dumb Question - Painting - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 01:37 PM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
Mixing paint - dumb question
I ended up having almost 3 gallons of a medium-gray paint left from another project. I thought my garage would be a good place to use it up, but the color is a bit dark. I also have about 2.5 gallons of off-white left here from the previous owner. The gray is eggshell, the white is satin - they are close so I wouldn't expect it would make much of a difference mixing them together.
For future reference though - if one were something like a semi-gloss with something like an eggshell (ore even a flat), what kind of results would one get mixing the two together?
Just one of those curiosity questions, I suppose.
hyunelan2 is offline   Reply With Quote
Old 04-08-2010, 01:57 PM   #2
Remodeling Contractor
if both are interior and both are latex you can mix fine. The sheen will be in between the two more towards the higher sheen.
Old 04-08-2010, 03:22 PM   #3
hyunelan2's Avatar
Rewards Points: 682
Thanks, that's exactly what I wanted to know.
Old 04-09-2010, 11:01 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
I do that all the time. Just mix them good. When you think you are done mixing, you are about 1/2 way there. Keep mixing.
Old 04-09-2010, 05:29 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
Mixing two sheens of the same type of paint generally get's something in between
I'd have to add a word of warning though, not all types of paints mix well
There are even some lines where even if you mix an older one and a newer (reformulated) one of the same line you will end up with gritty paint
slickshift is offline   Reply With Quote
Old 04-09-2010, 05:33 PM   #6
I keep a bucket of junk paint - I mix leftover whites
I only use it for non-critical areas
--main use is between floor joists so that basement lights will be brighter
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
New member, mixing valve question. morrow Plumbing 4 02-25-2010 09:55 PM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
Mixing sand with paint Mudball Painting 3 09-14-2009 10:18 AM
question on crappy paint job?? Doug Crf Painting 5 05-29-2006 10:52 PM
