Mixing Paint - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 03:43 PM   #1
Mixing Paint
I want to mix white interior flat paint with interior white primer paint both
water base. One quart primer to one gallon flat paint. Is it o.k.?
Have you done it before?Thanks.
Gaca2468 is offline   Reply With Quote
Old 06-17-2012, 03:49 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Not recommended- but will probably not be a problem. Why? And what paints?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-17-2012, 04:08 PM   #3
Mixing Paint
Because I have nothing to do with the quart of primer. They are both water base .
Old 06-17-2012, 04:51 PM   #4
Save it and use it as a primer. Paint and primer ( despite what some large box stores will tell you) do different things. They will mix, but neither will do what they were intended to as well, and you now have a mix that doesn't go with anything.
once again, what are you going to use it for?
Best Exterior Paint LoveWarrior Painting 14 04-08-2012 06:14 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
mixing paint 7echo Painting 6 04-29-2009 01:14 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
