Old 10-17-2012, 11:57 PM   #1
Mixing eggshell with flat?
Hello everyone,
I recently painted a wall with an eggshell sheen and it came out too glossy. Is it possible to mix the leftover eggshell with the same color in a flat sheen to reduce the glossiness? In other words, can eggshell and flat be mixed?
Thanks in advance,
David
DavidAl is offline   Reply With Quote
Old 10-18-2012, 04:11 AM   #2
paper hanger and painter
chrisn's Avatar
Personally. I would not do it, but, if you mix it VERY well and it is the same brand and base, it should probably work OK( maybe)
Hopefully Ric the man will come along with a short novel and explain
Old 10-18-2012, 07:47 AM   #3
Gymschu's Avatar
Don't do it. You will end up with dead spots on your wall. I've done it a few times over the years accidentally and it was a disaster.
Old 10-18-2012, 01:37 PM   #4
sdsester's Avatar
It might work out but why risk it? The chemistry has different resins and binders just to start. If you want to use the eggshell up? You could put it on as your first finish coat and then follow with flat for your final layer.
sdsester is offline   Reply With Quote
Old 10-19-2012, 01:38 PM   #5
As long as the paint types are the same, you can intermix them. It may be good to mix extra in the event that you need touch up paint. As Chris says, using the same brand and base is helpful.
Will22 is offline   Reply With Quote
Eggshell Finish Confusion fjmartinez Painting 5 05-24-2012 09:34 AM
Smooth walls with flat paint...looks weird to me? TOTALN00B Painting 3 04-25-2011 06:42 AM
mixing flat and semi-gloss paint together Flt_Simulation Painting 11 01-06-2011 10:51 PM
Washable Flat or Eggshell Paint? Kyle Painting 6 09-14-2006 11:42 PM
