Mismatched Finish - Painting - DIY Chatroom Home Improvement Forum
Old 11-28-2013, 01:29 PM   #1
Rewards Points: 85
mismatched finish
This is a newer house and has a knockdown finish applied to all the walls. I am finishing the basement and I am using just a thick coat of Kilzit, for a light texture, my problem is that the walls around the stairwell are knockout and the walls in the basement have little texture. The walls in the stairwell only extend to the bottom of the basement floor joists so where the walls meet I will have a texture problem. Aside from removing the texture in the stairwell, which I will do if necessary, is there any way to make this transition look right?
boilermaker27 is offline   Reply With Quote
Old 11-28-2013, 03:59 PM   #2
Gymschu's Avatar
Rewards Points: 460
Anytime there is texture involved and you are doing something to TRY and match, well, it won't. No matter how hard you try, there is almost no way to match the technique, conditions, compound used, etc. to match what's already there. A skilled drywaller can come very close. Your best option may be to remove the texture in the stairwell instead of experimenting with different techniques to match the texture that's already there.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
joecaption (11-28-2013)
Old 11-28-2013, 09:22 PM   #3
Rewards Points: 5,974
Maybe try some piece of moulding to separate the two.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (11-29-2013)
Need help figuring out how to finish knotty pine lizne Painting 12 10-20-2013 02:08 PM
Screen & recoat hardwood with old, possibly waxed finish? TomServo Flooring 0 10-15-2010 05:09 PM
Paint and finish advice for desk addypearce Painting 0 09-03-2010 10:03 AM
Seeking a darker finish for wooden cabinets chibear1986 Painting 8 08-25-2010 12:15 AM
Finish failure SidingHell Off Topic 5 05-20-2010 03:00 PM
