Minwax Wood Putty - Painting - DIY Chatroom Home Improvement Forum
Old 11-12-2013, 08:34 AM   #1
Minwax wood putty
Is it recommended to paint latex over minwax putty?
77wilson is offline   Reply With Quote
Old 11-12-2013, 10:11 AM   #2
Gymschu's Avatar
Rewards Points: 662
Usually Minwax putty is used when you want to match the color of your woodwork…….it fills the nail holes. Then a final coat of polyurethane, or other clear coats is applied to finish it off. If you are filling nail holes on woodwork that will be painted, just use spackle, let it dry, sand it flush with the wood, spot prime it with latex primer, and then apply your final topcoat.
If you paint over Minwax putty with ANY kind of paint, you usually get bleed through which will leave spots on your woodwork. I don't recommend it if you plan on painting your trim.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
Jmayspaint (11-12-2013), ToolSeeker (11-12-2013)
Old 11-12-2013, 11:42 AM   #3
Jmayspaint's Avatar
Rewards Points: 534
If you mean this stuff; http://www.minwax.com/mobile/wood-fi...wax-wood-putty
Then no.
Minwax does make wood fillers that are fine for use with latex, but not the putty. It's non drying oil base and can bleed through latex paint/ clear coats.
Jmayspaint is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Gymschu (11-12-2013), ToolSeeker (11-12-2013)
Replacing Windows in home with LOTS of wood DomiFamily Building & Construction 0 05-14-2013 11:38 AM
wood paint for fireplace box pberm1962 Painting 3 05-02-2013 08:22 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Finish options with wood putty? Whitmarsh Gal Carpentry 3 06-03-2011 07:05 AM
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 03:23 PM
