#1 |
STAFF
Minwax Polyshade or Stain and Finish
Which is recommended, Minwax Polyshade or stain and finish with water base poly. I am staining red oak wainscoting.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
#2 |
handpaintedbysteve.com
Hey jiju,
Let me be off the cuff and quick. Stay as far away from Polyshades as you can. I don't know what Minwax was thinking when they came out with that product, it's tricky to use, will scratch at a blink of an eye, does not penetrate into the substrate and if you make a mistake there's no going back to correct it. Stay with oil or water stain and poly.
Best of Luck Steve To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 | |
STAFF
Minwax Polyshade or Stain and FinishQuote:
#4 |
Forget the Polyshades.
![]() You will be wasting more time actually fixing the problems of the product than finishing. Basically it is varnish and pigments mixed together. My local paint store sold tons of that crap. |
| The Following User Says Thank You to StevenH For This Useful Post: | BigJim (04-16-2011) |
#5 |
Painting Company, NY
I would use an oil base stain, as a water base could raise the grain, not to mention that an oil base will penetrate the wood better. I prefer to use water base poly, as it is clear and does not yellow the stain. 2-3 coats
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
STAFF
Thank you for your information, that is the route I will take. I appreciate all of your help.
| Display Modes | |
| mixing polyu with minwax stain | rdmccaw | Flooring | 11 | 08-22-2012 03:55 PM |
| Need Advice - Stain finish over new paint? | Dgreaney | Painting | 4 | 02-20-2011 09:05 AM |
| Remove stain and finish from oak furniture | Rohey | Carpentry | 3 | 07-30-2010 08:03 PM |
| Finish failure | SidingHell | Off Topic | 5 | 05-20-2010 03:00 PM |
| one step stain and finish | RKH | Flooring | 2 | 05-04-2009 11:21 PM |
