Minwax Polycrilic - How Long Is It Good For? - Painting - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 01:31 PM   #1
Rewards Points: 45
Minwax Polycrylic - How long is it good for?
I have a half-full gallon of Minwax Polycrylic that I bought and used about 3 years ago. I live in Illinois and it has been stored in my garage, which is not temperature controlled. I am starting on a new staining project and I opened the Polycrylic up and it still looks fine, but should I be hesitant to use it? It isn't worth ruining my work if it is no longer good, but at the same time I would hate to go buy a new can if the old one is still fine.
CubsWin is offline   Reply With Quote
Old 10-10-2012, 04:06 PM   #2
Gymschu's Avatar
Rewards Points: 490
I've had a gallon can of Polycrylic for 5 years that I tap into now and then for various projects. Of course, I keep it in my basement which is cool and dry. Maybe try some on a scrap piece of wood to be sure it's ok.
Old 10-10-2012, 05:42 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Some things can withstand a freeze- others not so much. If you opened and stirred it and it looks OK- it probably is. They get weird when they go bad- usually not hard to tell.
.. Try not to freeze this winter- don't press your luck!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-10-2012, 11:24 PM   #4
Rewards Points: 256
Ditto what Brushjockey said.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 10-11-2012, 02:22 PM   #5
Too Short? Cut it Again!
If it froze and heated up to Midwest temps in the garage, I would error on the side of caution before using it on a large project. I most certainly would strain it into a new can. Then try it on a small sample to make sure it still cures. There are few things as pure fun as trying to get a non-cured sticky finish off of something.
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 10:23 PM
How long before color fades in top paints? jamiedolan Painting 4 08-01-2010 03:50 AM
Minwax vs Minwax CNM Design Flooring 0 02-24-2010 12:33 PM
Minwax Polyurethane vs. Minwax Polyurethane Floors proofer Flooring 3 04-06-2008 09:48 AM
