Minwax Mohogany Stain Isnt Dry - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 06:17 AM   #1
Rewards Points: 1,062
Minwax mohogany stain isnt dry
People,
I stained some baseboard with mohogany stain, can was stirred/mixed well first. Brushed it on, and left it alone. Did not pool any stain. This was yesterday, and this morning, some spots are still tacky. Can I coat now with poly (oil based) or what? Wont the tacky stain inhibit the poly from drying?
Why does it take so long for the stain to "dry"?
Thnaks
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 06-17-2012, 07:08 AM   #2
DIY staff
Rewards Points: 7,174
You missed a step---apply stain to raw wood--wait one minute or so--then wipe off excess stain with a dry clean rag---
At this point you may need to use a rag dipped into some paint thinner to remove the excess---then let it dry---
I apply stain with a rag--never a brush---I find it easier to control the amount that is laid on the wood.
noquacks (06-17-2012)
Old 06-17-2012, 07:50 AM   #3
Not to step on Oh Mike's toes, but if the stain looks uniform I would not use a rag with thinner as you'll risk marring it. It's not uncommon for spots of an oil finish to lag behind the rest in drying. I just had an issue with this on one door of a couple where a rail was still too soft to recoat after twenty four hours. I let it go, it dried and then I recoated. Drying times are not gospel. Be patient.
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
noquacks (06-17-2012), oh'mike (06-17-2012)
Old 06-17-2012, 07:56 AM   #4
DIY staff
Joe is right---be patient---proper staining technique requires a lot of experience --
fixing odd spots is done on a case by case basis--
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
Gymschu (06-17-2012), jsheridan (06-17-2012), noquacks (06-17-2012)
Old 06-17-2012, 08:06 AM   #5
Hmm, I kinda figured- but wanted yous input. Good advice to be patient!! Mike has a point, as I am aware of wiping off excess method, but yes, I too have seen where wiping can produce some "off" spots. Mike, I couldnt use a rag as the baseboard (and casings) have a grooved cross section profile- rag will not penetrate some of the "tighter" grooves.... brush is most practical way)
Just visited the garage again, and it apears that yes- the wood is more dry than I thought- with some "lagging" spots as mentioned. I wil coat poly maybe tomorrow!!!
Thnaks, People.
Old 06-17-2012, 10:52 AM   #6
Thnaks, People.
Let me guess, you are originally from the mid-atlantic area, more specifically somewhere within 200-300 mile radius of Philadelphia.
Minwax Polyshade or Stain and Finish BigJim Painting 6 04-04-2016 06:01 PM
mixing polyu with minwax stain rdmccaw Flooring 11 08-22-2012 02:55 PM
Minwax stain does not cover Minwax putty completely proofer Painting 18 11-17-2011 10:40 AM
Removing stain from deck machouinard Painting 20 09-08-2011 09:12 PM
waterbased polyurethane over minwax red mahogany stain? orgill Painting 1 09-05-2011 09:28 AM
