Mineral Spirits - Painting - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 11:55 PM   #1
Rewards Points: 172
Mineral Spirits
How do you know when a bottle of mineral spirits has gone 'bad'?
I was staining a couple of cabinets this evening and on the can of stain it said to clean the brush with mineral spirits.
So I found a bottle of it downstairs and poured some of it into a glass jar and set the brush I used for the stain into it.
A little while later I checked the brush by squishing it down into the jar a little bit and pulling it up to look at it.
I'm not trying to sound like a ditz, but there is something that looks like 'cottage cheese' stuck to the brush when I lift it. Is that normal and is mineral spirits supposed to look like milk? Is the bottle of it that I have outdated? I looked for a date on it, but couldn't find one.
Thanks in advance for your help.
gma2rjc is offline   Reply With Quote
Old 03-27-2013, 07:08 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
I have never seen MS go bad. If it is used, the paint in it will cloud it, but it eventually settles to the bottom. Maybe that is what you found.
Or perhaps it wasn't MS at all. I'd say smell test it, but I bet you probably don't know that smell as well as I do-
One other thought- there is a "non flammable" MS equivalent that is white. Usually comes in a white plastic jug.
Worthless in my opinion, but it might look like that.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
gma2rjc (03-27-2013)
Old 03-27-2013, 07:20 AM   #3
That sounds normal to me. If the brush sits for a while stuff will collect on the bristles. It will dissolve back into the spirits. Spin it out and rinse again until the spirits run clear.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 03-27-2013, 08:37 AM   #4
Rewards Points: 5,974
Agree have never known of MS going bad. After cleaning brushes we always let it set awhile the paint would settle to the bottom we then pour out the good stuff on top and keep reusing it.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 03-27-2013, 09:24 AM   #5
Rewards Points: 626
When it taste funny Just kidding
Nailbags is offline   Reply With Quote
The Following 2 Users Say Thank You to Nailbags For This Useful Post:
gma2rjc (03-27-2013), jsheridan (03-27-2013)
Old 03-27-2013, 05:26 PM   #6
Tool hit it. Pots of thinner brushes collect sludge on the bottom and it also coalesces on the bristles. Spin it out and rinse until clean.
Old 03-27-2013, 05:34 PM   #7
Yup. What you are seeing is the product you used getting partially dissolved on the bristles because you did not clean it out. If you just throw it in thinner without any cleaning that will happen.
I will use a 3 stage method- first wash gets most the gunk out, second a bit more, third I can either finish and dry or let soak ( for a short time) .
each stage can be about 1/4 cup for 1 brush..
I think cleaning oil is much easier than latex, just stinkier.
Old 03-27-2013, 05:34 PM   #8
Rewards Points: 192
I've never seen a bottle of mineral spirits "turn" or go bad and I have had some sitting for decades. Unless some one stuck something in the container to clean it and that is what you are seeing.
Larryh86GT is online now   Reply With Quote
The Following User Says Thank You to Larryh86GT For This Useful Post:
Old 03-27-2013, 06:46 PM   #9
Rewards Points: 172
Yes, this is a white bottle of 'odorless' mineral spirits - Klean-Strip Green. The liquid is also white.
I let the brush sit in the jar of it for about 4 hours and cleaned it out with a paint brush cleaner, then some soap & warm water.
The stain never really dissolved, it just came out of the brush in small globs and it took a long time to get it all out.
Thanks for the replies everyone.
Old 03-27-2013, 07:01 PM   #10
cdaniels's Avatar
[QUOTE=gma2rjc;1147290]Yes, this is a white bottle of 'odorless' mineral spirits - Klean-Strip Green. The liquid is also white.
Thanks for the replies everyone.[/QUOT Yep.I tried some of that so called solvent once.....It hasn't gone bad it was never any good to begin with.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 03-27-2013, 07:41 PM   #11
CD- I hope that was a synth brush- if you used a natural bristle brush the water would make it bush out and be worthless.
Old 03-27-2013, 08:43 PM   #12
The only thing that Kleen Strip Green strips is you of your green. It's worthless. I bought a gallon of it once and ended up throwing about three quarters of it away. You said it came out of the brush in globs, that tells me it's not a reducer, like true paint thinner. I'm going to take a chance and say that brush is not clean and once dry will harden up. If the heel hardens up the brush is then trash or good as a paint dust brush.
Old 03-27-2013, 10:16 PM   #13
Rewards Points: 172
I should have known it wouldn't be any good as, in my experience, there aren't very many "green" cleaning products that do half the job of the products they are trying to replace. I'm sure there are exceptions.
Brushjockey, I just went to check on the brush. It's dried now and as you said, it did bush out. Bummer.
Old 03-27-2013, 10:31 PM   #14
Some here don't think I know what I'm talking about.
Bad news. I do ( not intended for you ..)
Old 03-27-2013, 10:40 PM   #15
Agree, there are no decent "green" products when it comes to solvent alternatives.
At least you now have a good dust brush. Cut the handle off and it fits perfectly in the back pocket, handy for whenever you need to do some dusting when painting.
metal preparation DexterII Painting 2 09-27-2012 10:09 AM
Minwax stain does not cover Minwax putty completely proofer Painting 18 11-17-2011 11:40 AM
Mineral Spirits causing arm pain diyrocks Painting 10 02-07-2011 01:08 PM
Over-applied Cabot's Australian Timber Oil... Mineral Spirits?? Ler0y Jenkins General DIY Discussions 4 06-08-2010 08:32 AM
Paint Thinner (mineral spirits) or TSP? Is there a difference? Painting Scotsman Painting 7 11-26-2009 12:05 AM
