Mildew On LogHome - Painting - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 07:57 PM   #1
Mildew on LogHome
3 years ago I had my log home sand blasted to remove a solid stain that had been previously applied. I re-stained the house using California Storm Stain Semi-Transparent oil based. Mildew problems have been terrible with this application.
I want to clean the house with Jomax /bleach and re-stain. Is this my best bet? If yes, I know I should wet plant life first but should I wet the house before putting on the Jomax solution?
When I re-stain should I use a different product? Perhaps a Latex or water based product. My understanding is the mold tends to feed on oil based stain and latex would be a better alternative.
I still want to use a semi-transparent? Has anyone used California storm-stain latex based semi-transparent?
What about adding an additive to the stain or is this just a gimmick?
Thank you Bob
bob_m is offline   Reply With Quote
Old 03-29-2009, 09:58 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
If Sikkens is available in your area, I'd recommend that
They have Log Home specific products
They are particular about recommending prep, and I believe they will ask you use a TSP/Bleach/Water mix, although I have used the Jomax/Bleach/Water for prep for Sikkens before
It would def. be worth it to check out their website for info, and to see if it's available
slickshift is offline   Reply With Quote
Old 03-29-2009, 11:37 PM   #3
I use the bleach/jomax mix with good results. You can add a mildewcide in the stain for extra protection. It will probably help some but the stain already has a mildewcide in it.
waynech is offline   Reply With Quote
mildew ceiling in bathrm kevin-redsoxfan Building & Construction 5 12-24-2008 08:36 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
