Mildew On Joists, Clean Before Kilz? - Painting - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 01:55 PM   #1
Question
Mildew on joists, clean before kilz?
Hello all, I'm recovering from a leak in a hot water pipe. The water had been spraying a fine mist onto the plywood subfloor under the house and as well as a little on the joists around it. I've ripped out all the damaged subflooring but there is some mildew on the joists. I've had a commercial cyclone fan blowing on the joists for a week now and they are dry but there is still powdered mildew on them. Should I clean them with bleach and water before I paint them or just paint them?
FYI, the joists themselves haven't been structurally compromised they just have mildew on them.
Jimmyjo is offline   Reply With Quote
Old 11-25-2011, 02:21 PM   #2
Rewards Points: 1,062
bleach will kill the surface mold, but the hyphae (roots) extend very deep into the wood. Also, you dont want to inhale bleach vapors. And never use bleach straight out of the bottle- way too strong, and unneccessary.
Use a mildewcide spray like lysol/store brand (make sure to read the ingredients to find the ingredient benzylalkylammonium chloride, or close to that (there are different spellings). Again, no need to buy National brand- alls the same!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-25-2011, 02:22 PM   #3
Also, peroxide 3% from store kills mold very well,, and no stink!
Old 12-12-2011, 02:06 PM   #4
Lightbulb
Thanks for the heads up!
Sorry it's taken so long to reply. I followed your instructions NoQuacks about using Lysol. Man, what a mess that was but definately the way to go. First thing I did was scrub the joists with a mixture of bleach and hot water, let them dry with a big fan, then repeated with Lysol. It was probably overkill but the peace of mind is worth it to me.
Since then I've painted the joists with Kilz and there hasn't been any bleed through or discoloration of any kind. The next step is to put down the subflooring so I can then finally put down the new laminate flooring I bought 2 months back.
Hopefully I'll have this done before christmas!
Tags
mildew , paint , water damage
Any way to splice joists together? tpagel Carpentry 26 04-28-2011 05:32 PM
Bearing surface for joists - home addition benjamincall Building & Construction 6 04-05-2011 04:49 PM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Options for bridging floor joists. atxjoe Building & Construction 1 02-10-2011 09:31 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
