-   -   Mildew on joists, clean before kilz? (http://www.diychatroom.com/f4/mildew-joists-clean-before-kilz-124564/)
Jimmyjo 11-25-2011 01:55 PM
Hello all, I'm recovering from a leak in a hot water pipe. The water had been spraying a fine mist onto the plywood subfloor under the house and as well as a little on the joists around it. I've ripped out all the damaged subflooring but there is some mildew on the joists. I've had a commercial cyclone fan blowing on the joists for a week now and they are dry but there is still powdered mildew on them. Should I clean them with bleach and water before I paint them or just paint them?
FYI, the joists themselves haven't been structurally compromised they just have mildew on them.
noquacks 11-25-2011 02:21 PM
bleach will kill the surface mold, but the hyphae (roots) extend very deep into the wood. Also, you dont want to inhale bleach vapors. And never use bleach straight out of the bottle- way too strong, and unneccessary.
Use a mildewcide spray like lysol/store brand (make sure to read the ingredients to find the ingredient benzylalkylammonium chloride, or close to that (there are different spellings). Again, no need to buy National brand- alls the same!
noquacks 11-25-2011 02:22 PM
Also, peroxide 3% from store kills mold very well,, and no stink!
Jimmyjo 12-12-2011 02:06 PM
Thanks for the heads up!
Sorry it's taken so long to reply. I followed your instructions NoQuacks about using Lysol. Man, what a mess that was but definately the way to go. First thing I did was scrub the joists with a mixture of bleach and hot water, let them dry with a big fan, then repeated with Lysol. It was probably overkill but the peace of mind is worth it to me.
Since then I've painted the joists with Kilz and there hasn't been any bleed through or discoloration of any kind. The next step is to put down the subflooring so I can then finally put down the new laminate flooring I bought 2 months back.
Hopefully I'll have this done before christmas! :eek:
