Metal French Doors - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 08:31 AM   #1
Metal french doors
Yesterday, I painted my french doors with the paint with primer. Today, I can scrape it off with my nail. Did I not let it dry enough between coats?
Jeanette Hollan is offline   Reply With Quote
Old 02-26-2011, 09:02 AM   #2
You probably hould have gone with a DTM (direct to metal). All of the major paint companies have them. The paint/primer deal seem to be a marketing niche for the big box stores but lack in quality. As far as dry time between coats follow the label directions. Manufacturers are usually pretty conservative in regards to that. Prep is also a key. You should scuff the doors and wipe the dust off with a tack cloth or a thinner rag and allow to dry. This will give the paint a good bond.
kboyz is offline   Reply With Quote
Old 02-26-2011, 09:47 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
The paint with primer is a lie. They are marketing that hoping peple are painting already painted surfaces which usually doesn't need a primer anyways.
Old 02-26-2011, 11:13 AM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
If they are metal I would use Sherwin Williams DTM on them. I don't believe paint that claims its paint and primer, as primer serves one function and paint serves another function. Also paint is usually dry to the touch shortly after applied, but it actually needs up to 30 days to actually cure.
housepaintingny is offline   Reply With Quote
Old 02-26-2011, 12:11 PM   #5
Gymschu's Avatar
Rewards Points: 666
Any regular paint put on a metal door is gonna require some serious dry time. The paint literally lays on the surface and does not soak into the metal like it would on something like drywall. I'm also of the opinion that a good scuff sanding is in order to give something for the paint to "bite" into. Like many others have said, a DTM (direct to metal) paint is made for these types of applications and is a safer bet than Behr's paint and primer in one.
misplaced hinges french doors lax018 Carpentry 1 07-01-2010 05:15 PM
French Doors - help chpwaman General DIY Discussions 4 12-18-2009 08:13 AM
leaky French doors? llucas3 Building & Construction 2 12-02-2009 09:39 AM
center hinged to french doors oneroom42 Carpentry 3 12-17-2008 12:07 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
