Old 12-10-2006, 02:52 PM   #1
Do'n-To-do-list
Matching plaster texture
I have a home built in 1950. I replaced a large fixed window (6'x8') with a smaller (4'x8') operable window. Under the new window is a new smooth GWB wall. Now I need to match the original swirling plaster pattern. It is a smooth finish with many coats of paint over it. There are places where they may have pressed a rag or cloth into it. Two photos are attached. Any suggestions on how to create this texture?
David
DTSpangler54 is offline   Reply With Quote
Old 12-11-2006, 12:13 AM   #2
Pro Painter
you might want to try the drywall forum, or search for a plaster forum.
The bottom pic looks like it might be a variation of the old time coffee can method. They used to use the bottom of cans to get the circles. Usually on ceilings.
That looks like a can, some more manipulation and burnishing (sanding). But, I'm not a plaster man.
The top picture....I have no idea.
joewho is offline   Reply With Quote
Old 01-01-2007, 09:57 PM   #3
Try a wet towl or rag that should do it with a coffee can
Dwallguy is offline   Reply With Quote
Old 01-02-2007, 04:21 AM   #4
Pro Painter
http://forum.doityourself.com/archiv....php/f-27.html
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
Matching Ceiling Texture WorkOnIt Painting 7 05-14-2007 10:46 AM
Drywall/plaster Texture? AlbrightPM General Discussion 17 12-14-2006 08:11 PM
Plaster removal decision Sarai Remodeling 2 09-08-2006 04:15 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 04:50 PM
