Matching plaster texture
2 Attachment(s)
I have a home built in 1950. I replaced a large fixed window (6'x8') with a smaller (4'x8') operable window. Under the new window is a new smooth GWB wall. Now I need to match the original swirling plaster pattern. It is a smooth finish with many coats of paint over it. There are places where they may have pressed a rag or cloth into it. Two photos are attached. Any suggestions on how to create this texture?
David |
you might want to try the drywall forum, or search for a plaster forum.
The bottom pic looks like it might be a variation of the old time coffee can method. They used to use the bottom of cans to get the circles. Usually on ceilings. That looks like a can, some more manipulation and burnishing (sanding). But, I'm not a plaster man. The top picture....I have no idea. |
Try a wet towl or rag that should do it with a coffee can
| All times are GMT -4. The time now is 12:43 AM. |
