Old 09-01-2009, 02:56 PM   #1
matching paint comes out gray
I have a painting problem that I cannot solve. I have painted interior drywall; I repaired a crack and a couple of holes by using spackling and primer. When I applied matching paint, the area I painted turned a gray instead of the cream color it was. A second coat still turned gray. It looks horrible.
I applied a little paint to an untouched area of drywall and it, too turned grayish. I then went down to the basement, found an unpainted piece of drywall and applied the cream-colored paint. Perfect! Yet it turns grayish on the installed wallboard.
Some suggestions will get me sane again. Thanks.
mmsuki is offline   Reply With Quote
Old 09-02-2009, 06:55 AM   #2
Doer of Many Things
poppameth's Avatar
Try priming a spot with Zinsser BIN, a white pigmented shellac primer. Then apply your topcoat and see if the BIN stops whatever is causing the color change from bleeding through.
poppameth is offline   Reply With Quote
Old 09-02-2009, 11:24 AM   #3
Coatings Nerd
How long ago was the original paint put on?
NCpaint1 is offline   Reply With Quote
Old 09-02-2009, 12:49 PM   #4
The walls were painted about 3-4 years ago.
Old 09-02-2009, 12:49 PM   #5
Thank you for the help. I will try that primer. I used KILZ during this fiasco.
Old 09-03-2009, 06:53 AM   #6
Doer of Many Things
poppameth's Avatar
Kilz original oil is okay. All other Kilz is pure junk.
Old 09-03-2009, 10:31 AM   #7
Coatings Nerd
Could be why it's not touching up, even when the original paint is being used. Especially if it is a finish with any type of sheen (gloss) Worst case scenario, paint corner to corner and all should be fine.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
