Masonary Paint - Painting - DIY Chatroom Home Improvement Forum
Old 12-23-2013, 06:11 PM   #1
Rewards Points: 14
Masonary paint
I just purchased 2 concrete block buildings that I will remodel into convenience stores.What is a good paint I can use that will last for years and can be washed. Thanks ,Glenn
G Archer is offline   Reply With Quote
Old 12-24-2013, 08:31 AM   #2
Rewards Points: 5,974
Really need some more info. Have they ever been painted before? Have they been sealed with block filler? I just received a contractor brochure from Sherwin Williams with an article about a new product for concrete and masonry it is called SherLastic 100% Acrylic Elastomeric Coating and it is touted for both residential and commercial. Maybe go on website and read up on it, sounds like what you need.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (12-24-2013)
Old 12-24-2013, 09:27 AM   #3
Gymschu's Avatar
Rewards Points: 680
Loxon Primer and Sherlastic topcoat and that bldg.'s paint job will last for years.
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
HighGlossPL38 (12-29-2013)
Old 12-25-2013, 10:34 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Many many years.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 12-26-2013, 05:49 PM   #5
Rewards Points: 14
The buildings have been painted before and there seems to be no loose and peeling paint.. Glenn
Old 12-26-2013, 08:24 PM   #6
If they have been painted and it is in good condition you probably can skip the primer.
Gymschu (12-26-2013)
Old 12-27-2013, 04:36 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 320
Originally Posted by audrycampbell View Post
Masonry paint is the specially formulated house paint that beautifies and protect new or previously painted drywall on both the anterior and exterior of the home.
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (12-27-2013)
Old 12-27-2013, 07:43 AM   #8
Sorry but this is TOTALLY wrong masonry paint is for concrete and concrete materials in other words masonry hence the name masonry paint and should not be used on drywall.
Old 12-27-2013, 07:54 AM   #9
Rewards Points: 4,796
Not even on exterior drywall?
jeffnc is offline   Reply With Quote
Old 12-27-2013, 08:23 AM   #10
Gymschu's Avatar
Rewards Points: 680
He/She had me at "anterior."
Will22 (12-27-2013)
Old 12-27-2013, 09:14 AM   #11
concretemasonry's Avatar
Rewards Points: 2,594
"Masonry paint" is a generic term and thus, very vague.
For painting over MASONRY (block and concrete,) a product like Thoroseal is a superior material to use because it is NOT a PAINT. For concrete block (especially coarse textured), it provide a far more usable surface than "concrete filler" because it becomes a part of the wall (very dense) and provide the type of surface to apply paint-type coatings to.
It is not for quick and dirty painter or DIYer, because it is heavy and thick material depending on what consistency you chose to mix it to. It can hide mortar joints and large voids with a thick coat and follow the next day with a thinner more finished coat. Mixing procedure is critical. It is not an easy material to use and misting the surface before using is critical, but worth the effort.
I have used it on dam restorations, on interior and exterior buildings and the resulting surface is extremely durable and ready for painting or surfacing.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Old 12-27-2013, 09:18 AM   #12
Certainly you use different drywall toward the front of your house than in the back, right? It's more important to make a good impression to arriving guests.
Old 12-27-2013, 05:05 PM   #13
Dick
For a number of years I have been using SW block filler and lately elastmeric paint. The block filler is thick about 50sf to a gallon and need a sprayer that will shoot a 32 tip. Then it must be back rolled. I have never used or really heard of the product you recommend. Are they also the maker of the paint?
Maybe I should say all I have done is block or stucco.
Old 12-27-2013, 05:23 PM   #14
The product is a commercial product and is usually not readily available. Been around for about 50 years for engineering and commercial applications. It is definitely not a common residential product because of the effort and timing of applications, so paint fillers have been used for mundane applications.
Dick
ToolSeeker (12-27-2013)
Old 12-29-2013, 05:17 PM   #15
Dick
Been using it for year, excellent cement based product. And fantastic for waterproofing issues.
HighGlossPL38 is offline   Reply With Quote
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
