09-30-2011, 12:55 AM
#1
Masking Tape Adhesive Remover?
Guys -
I need to remove some masking tape goo from a master bedroom closet that's been primed but not top-coated. The tape was some creme-colored stuff (i.e., not the blue Scotch 3M stuff) that has a sticky factor of about a billion. Has been on the wall for about 2 years. Got distracted on other DIY projects remodeling my home. Yeah, brilliant I know.
I tried 409 and a toothbrush, warm water with liquid hand soap and a toothbrush, and a scotch-brite pad with 409. No luck.
Anybody know of a good tape adhesive remover that won't rip off the existing layer of primer/force me to reprime? (And, to be clear, the adhesive remover itself doesn't have to be "tape", it just needs to be able to remove the masking tape adhesive/sticky stuff left behind.)
09-30-2011, 04:11 AM
#2
paper hanger and painter
Originally Posted by Twister
Guys -
Anybody know of a good tape adhesive remover that won't rip off the existing layer of primer/force me to reprime?[/
NO, but goof off will get the tape off
The Following 2 Users Say Thank You to chrisn For This Useful Post:
09-30-2011, 06:23 AM
#3
the Musigician
WD-40 might help.
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
09-30-2011, 08:57 AM
#4
Rubbin walls since'79
Mineral spirits works.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
09-30-2011, 09:17 AM
#5
chrisn and DangerMouse -
Thanks, guys, for your suggestions. I'd heard of Goof-Off but never heard the idea of trying WD-40. Will have to give them a try and let you know how it worked.
(chrisn, in the "it's a small world" category, my son recently arrived in your town on a 2 yr church-service mission. Says he likes Hagerstown.)
09-30-2011, 09:21 AM
#6
Mineral spirits? Is that the same as paint thinner?
09-30-2011, 09:24 AM
#7
yes- but not the hotter solvents. usually tales a little elbow grease too when it's been that long. Lube up with the thinner, then gently scrape with a putty knife. might have to finish with a scrubbie, the glue will ball up.
09-30-2011, 11:53 AM
#8
Guys -
My wife showed me a product we had (didn't know we had it) called "Goo Gone". Worked AWESOME! I also had her buy a can of "Goof Off" to compare. The Goof Off worked quite well but required a little more aggressive rubbing and looked like it might have even started to remove the subtle orange peel texture from rolling the wall. I would have been thrilled with the Goof Off if she hadn't pointed out the Goo Gone. The Goo Gone required less elbow grease and also a slight orange scent to it, a bonus if anyone out there doesn't like solvent-based products.
I appreciate everyone's comments, but in the end, what worked best was "Goo Gone" by Magic American Corporation. If anyone can't find it, you can call them at (216) 464-2353.
Cheers!
09-30-2011, 12:27 PM
#9
Make sure you do not use anything that contains oil or any oil byproducts. They will soak into the surface and make it very hard for additional paint to adhere in the future.
09-30-2011, 05:20 PM
#10
[quote=Twister;738814]chrisn and DangerMouse -
(chrisn, in the "it's a small world" category, my son recently arrived in your town on a 2 yr church-service mission. Says he likes Hagerstown.)[/quote]
Cool, which church? You don't have to answer if you dont want to, I understand. Also good going with the goo gone.
09-30-2011, 08:21 PM
#11
Unfortunately, the Goo Gone is made with "petroleum distillates" (distilled products) so I wiped it down immediately with a water-soaked sponge. I hope that's good enough because I did it over 9 hours ago.
Break // Break.....
Anyone out there..... if you've used "Goof Off", "Goo Gone" or other similar products, have you ever had any problems with the cleaned area rejecting paint?
09-30-2011, 08:27 PM
#12
[quote=chrisn;739054]
He's a missionary for the Church of Jesus Christ of Latter-day Saints (the 'Mormon' church). The Goo Gone cleaned up the tape goo AWESOME. I just hope I don't have problems with the paint not sticking now.
Still appreciate everyone's comments!
The Following User Says Thank You to Twister For This Useful Post:
09-30-2011, 08:31 PM
#13
While it does have some distillate products I've found in the past that Goo Gone doesn't cause a problem with future painting.
The Following User Says Thank You to Msradell For This Useful Post:
10-01-2011, 02:42 PM
#14
Msradell -
Thanks for the info. Want to learn how to do things right.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
