Marrying A Purdy Pole To A Wooster Frame - Painting - DIY Chatroom Home Improvement Forum
Old 06-27-2012, 09:33 AM   #1
Marrying a Purdy pole to a Wooster frame
Is there any way to attach a Purdy Pro Extra pole to a Wooster Sherlock Wide Boy frame? Any adapter or fitting available? I didnt realize that the two would not go together when I bought them.
If there is no solution, I'll have the trouble of returning the pole. I would prefer to use the Wide Boy frame.
I am going to use 18" rollers.
OneAkela is offline   Reply With Quote
Old 06-27-2012, 05:59 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
I don't think so. They intentionally make them non compatible. But get the Wooster. The whole Sherlock system is the best.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-27-2012, 07:37 PM   #3
Thanks. I thought as much. I ordered the Wooster pole and am returning the Purdy.
Old 06-28-2012, 03:32 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
There is an adaptor. It should also thread into the bottom of your roller pole for when you are not using it.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-28-2012, 05:32 PM   #5
True- but it turns it into another threaded pole which looses the whole reason to get a good system- non turning connection.
Old 06-28-2012, 05:58 PM   #6
I agree. Those lock systems are pretty sweet.
Moving a internal door frame Marie1 Building & Construction 2 05-19-2012 08:08 PM
narrow frame dual pane windows tns1 Building & Construction 0 12-21-2010 02:05 PM
exterior door frame size and rough opening kevincw01 Building & Construction 3 06-06-2010 08:26 AM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 02:23 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
