Marine Enamel Vs House Enamel - Painting - DIY Chatroom Home Improvement Forum
Old 05-19-2012, 10:03 AM   #1
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
Marine Enamel vs House Enamel
What is the difference between house vs Marine enamel paint. I know the Marine is around $23 a QUART. Will the Marine cover as much as the house enamel. I can't seem to find much information about this online. The application would be exposed to all types of weather and rain.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 05-19-2012, 10:25 AM   #2
Too Short? Cut it Again!
You might dig online for the spec sheets for the brand of marine enamel you have in mind.
Somewhat like porch and floor paints, marine enamels tend to come with either urethane (in alkyd oil based) or epoxy (water based acrylics) reinforcements. Some, like hull paints are sometimes even two part systems. There are nano silicon marine paints now too and of course anti-fouling teflon products. Some have inhibitors that are supposed to keep barnacles from attaching, mold from growing etc. Of course there are those with rust converters or inhibitors.
They will probably not get you the same coverage as household paint products but if your situation really calls for extreme weather resistance they are worth considering I guess. Your color choices may be limited although there are tons of factory colors.
What are you trying to paint or protect? A porch and floor or patio paint, like Benjamin Moore's, might be a less expensive choice?
Here are the specs for Sherwin Williams marine coatings.
http://protective.sherwin-williams.com/coatings/categories/template.jsp?N=23&Ns=p_name|0||p_sku_display_order
Old 05-19-2012, 05:07 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
My stars that is a bunch of info and some of it is way over my head. I plan to use a good enamel and canvas for a roofing system for my camper. I had thought about using Gaco roof coating over the enamel but now I am not sure I will, I may just go with the marine enamel and canvas. I appreciate the information.
Jim
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 03:57 PM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 02:54 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
