Making A Flat Paint Flatter - Painting - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 10:09 AM   #1
making a flat paint flatter
I'm trying to match the paint that came with my home. The builder watered down the paint and it is very flat and very thin.
I've tried to match the paint at BM, lowes and HD and although they can get the color right none can match the sheen. My flat paint is FLAT!!!!.
The other flat paints (BM ben flat, Glidden flat and Valspar flat) have more sheen than whats on my walls.
Is there an additive that can reduce the sheen even further for a flat paint. I'm pretty sure the builder watered down his paint before shooting it because I could see through it in the bathroom where they switched from white sheetrock to the green stuff in the wet areas.
Water it down maybe?
cousindan is offline   Reply With Quote
Old 02-25-2012, 10:37 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
You need a cheap builder grade latex, that is all latex. Most paints now have acrylic in them instead of being a pure vinyl or latex. The acrylic causes some sheen even in flats. Basically you need cheap paint to get that look. Any quality product is going to have acrylic in it and at least a slight angular sheen.
Darkling Designs
poppameth is offline   Reply With Quote
Old 02-25-2012, 10:55 AM   #3
Rewards Points: 13,300
If the paint jobs that bad why would you not just repaint the walls instead trying to match it?
You do know that using flat paint on the walls will show hand marks and be hard to clean, right?
Old 02-25-2012, 11:25 AM   #4
You need a cheap, cheap builders flat. They have no sheen because they're basically all chalk or clay.
Old 02-25-2012, 11:27 AM   #5
Rewards Points: 386
Good Point, JC...as the paint evangelist says "Repaint and thin no more"
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
Gymschu (02-25-2012)
Old 02-25-2012, 11:36 AM   #6
Rubbin walls since'79
Brushjockey's Avatar
I agree with both- for the amount of time you probably have already spent running around, you could have upgraded to a quality finish.
A builders flat is good to prime with a primer sealer- because it will suck the life out of a first coat or two of anything good.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-25-2012, 11:55 AM   #7
ltd
Rewards Points: 536
seriously who knows what it is ?you could call the builder and maybe get the number of the painter and he could tell you what he used.just don't hold your breath. builders flat , in other words cheep flat paint, is like a dirt magnet. if you like the color thats on the walls now get it in a quality washable flat or matte.same color flat on flat you could do it one coat
ltd is offline   Reply With Quote
Old 02-25-2012, 11:58 AM   #8
Builders and people turning houses like to use flat because it helps hide all the flaws in the sheetrock finishing.
Old 02-25-2012, 12:05 PM   #9
ltd
Rewards Points: 536
i like that it took me a couple times but yea thats good
Old 02-25-2012, 01:42 PM   #10
BINGO!!!
The sheetrock job as a lot of imperfections and the flat is alot more forgiving than say an eggshell.
I'm going to go through the house and fixing the sheetrock problems like mud runs on the corners, pi## poor caulking in trim and the occational ding here and there. I'm not ready to repaint the entire interior just yet so a quart of touchup paint is all I need.
Old 02-25-2012, 03:35 PM   #11
Too Short? Cut it Again!
Stop it!
Old 02-25-2012, 05:29 PM   #12
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
Originally Posted by sdsester View Post
Stop it!
Hey, at least he did not want them to tear it all out and start over
chrisn is online now   Reply With Quote
Flat Ceiling Paint Lsuhunter55 Painting 3 04-18-2011 10:32 PM
Using Flat Paint on Flat Paint that had been touched up with Gloss! Russell_Case Painting 1 01-17-2009 07:58 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 09:13 PM
Flat paint leeddsd Painting 4 03-16-2008 08:23 AM
