-   -   making a flat paint flatter (http://www.diychatroom.com/f4/making-flat-paint-flatter-134977/)
cousindan 02-25-2012 10:09 AM
I'm trying to match the paint that came with my home. The builder watered down the paint and it is very flat and very thin.
I've tried to match the paint at BM, lowes and HD and although they can get the color right none can match the sheen. My flat paint is FLAT!!!!.
The other flat paints (BM ben flat, Glidden flat and Valspar flat) have more sheen than whats on my walls. :censored:
Is there an additive that can reduce the sheen even further for a flat paint. I'm pretty sure the builder watered down his paint before shooting it because I could see through it in the bathroom where they switched from white sheetrock to the green stuff in the wet areas.
Water it down maybe?
poppameth 02-25-2012 10:37 AM
You need a cheap builder grade latex, that is all latex. Most paints now have acrylic in them instead of being a pure vinyl or latex. The acrylic causes some sheen even in flats. Basically you need cheap paint to get that look. Any quality product is going to have acrylic in it and at least a slight angular sheen.
joecaption 02-25-2012 10:55 AM
If the paint jobs that bad why would you not just repaint the walls instead trying to match it?
You do know that using flat paint on the walls will show hand marks and be hard to clean, right?
jsheridan 02-25-2012 11:25 AM
You need a cheap, cheap builders flat. They have no sheen because they're basically all chalk or clay.
ric knows paint 02-25-2012 11:27 AM
Good Point, JC...as the paint evangelist says "Repaint and thin no more"
Brushjockey 02-25-2012 11:36 AM
I agree with both- for the amount of time you probably have already spent running around, you could have upgraded to a quality finish.
A builders flat is good to prime with a primer sealer- because it will suck the life out of a first coat or two of anything good.
ltd 02-25-2012 11:55 AM
seriously who knows what it is ?you could call the builder and maybe get the number of the painter and he could tell you what he used.just don't hold your breath:huh:. builders flat , in other words cheep flat paint, is like a dirt magnet. if you like the color thats on the walls now get it in a quality washable flat or matte.same color flat on flat you could do it one coat
joecaption 02-25-2012 11:58 AM
Builders and people turning houses like to use flat because it helps hide all the flaws in the sheetrock finishing.
ltd 02-25-2012 12:05 PM
i like that :laughing: it took me a couple times but yea thats good
cousindan 02-25-2012 01:42 PM
BINGO!!!
The sheetrock job as a lot of imperfections and the flat is alot more forgiving than say an eggshell.
I'm going to go through the house and fixing the sheetrock problems like mud runs on the corners, pi## poor caulking in trim and the occational ding here and there. I'm not ready to repaint the entire interior just yet so a quart of touchup paint is all I need.
user1007 02-25-2012 03:35 PM
Stop it!:furious::furious::furious::furious:
chrisn 02-25-2012 05:29 PM
Hey, at least he did not want them to tear it all out and start over:laughing:
