Makeshift Paint Sprayer? - Painting - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 03:40 PM   #1
Rewards Points: 298
makeshift paint sprayer?
I've got to paint/stain an older wooden playset. It doesn't have to be perfect. Is there anything cheap and easy I can use as a sprayer, where I can just dump in stain/poly/paint and spray it on? Maybe something with a pump like a weed-killer sprayer?
denemante is offline   Reply With Quote
Old 04-05-2012, 04:22 PM   #2
ARC Painting's Avatar
You could use a pump sprayer as you say. I'm no spraying expert, but you won't get great results using a pump sprayer. and you'd probably have to back brush it to get it to penetrate well and look even. It would save some time in applying the stain, yes.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Old 04-05-2012, 06:09 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
A weenie roller and back brushing will be about your fastest cheap solution.
As Arc said - with a bug sprayer you will still need to brush it in.
Sometimes you just got to lay yer ears back and do it. Once you get a feel for it it moves right along, but there is no stain cannon that will take the work out of it.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (04-05-2012)
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
central paint sprayer jaccaj Painting 1 02-19-2012 06:31 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
paint sprayer.. mpower22 Tools 1 02-25-2008 05:18 AM
