Low VOC Interior Primer - Painting - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 02:27 PM   #1
Low VOC interior primer
Need to paint two interior rooms and can't decide which place to go for low or zero VOC primer. I've had good luck with BM Eco Spec before but Sherwin Williams is having a 40% sale this weekend. Has anyone used either and has a recommendation? Thanks.
farmery is offline   Reply With Quote
Old 04-18-2013, 04:24 PM   #2
Stick with what you know and had luck with. First of all, SW prices are higher overall than BM. Secondly, if you're not happy for whatever reason with the SW, is it going to be worth the few little bucks you saved? Stick with what you know and had luck with.
Old 04-18-2013, 06:34 PM   #3
Too Short? Cut it Again!
I think Ben Moore may be matching SW prices for the sale. If not, they will be running one similar soon. The Ben Moore store or department manager may be able to match the discount in any event.
Old 04-18-2013, 10:54 PM   #4
Painting Contractor CT
Rewards Points: 77
Post
I would recommend using Benjamin Moore primer or paint. From our experience, they're slightly better when it comes to interior primer/paint.
Good Luck!
KD PAINTING is offline   Reply With Quote
Old 04-19-2013, 03:44 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Good Luck!
interior only?
Old 04-22-2013, 01:45 PM   #6
Rewards Points: 394
The majority of interior primers are around 100g/L VOC, which is low. There are also some no-VOC primers, which are generally higher grade products.
Will22 is offline   Reply With Quote
Old 04-22-2013, 01:57 PM   #7
Rubbin walls since'79
Brushjockey's Avatar
If you are repainting over a sound previously painted surface- unless it is glossy or would have other adhesion problems, a primer is not needed.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
